Question about Dell E173FP 17" LCD Monitor
Screen will only open for a couple of seconds. I think someone changed the imput settings, but I can't get the screen to stay open long enough to adjust it
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Rhettpayne, When you say: "can't get screen to stay open" do you really mean to say that the SCREEN WENT TOTALLY BLACK!! If such is the case then you may have a common problem that E173FP and E173FEP units have. I think that you really need to visit YOUTUBE and search for and view the longer 8-10min. video clips of "LCD monitor disassembly" and also "LCD repair" !! I think your monitor suffers from THERMALLY STRESSED printed circuit board solder joints and /or SWOLLEN power supply filter CAPACITORS. In the case of this model DELL units it could be either one or both types of failures inside your monitor. Also web search www.ccl-la.com/badcaps.htm for info. and www.badcaps.net Some of these monitors can be fixed for less than $10 in parts. Get back here on fixya with a NEW comment added to your original post and tell us if you have done the LCD flashlight test and your results of test. I'm louie12fix on fixya or lmistyrel @ aol.com hope this helps you out. Please rate this response on fixya.
Posted on Oct 08, 2009
Thin black horizontal line at top of lg 60 in. tv. Line appears on both HDMI imputs,
Only at the top??? Really? Go into your settings use your remote obviously, click on menu, and go to picture settings. I have an LG TV as well, Im thinking the remotes should be relatively close enough to the same. Look for you screen settings in your menu
Dec 02, 2016 | LG Televison & Video
My galaxy s5 screens stays on all the time unless I push the button to turn it off. It never did this before, how do I fix it
Try *Settings* *Display* and make sure the box in the *Smart stay* item is NOT CHECKED. This may or may not be it depending on if you continue to look at it or if you place it close to something where it thinks you're looking at it.
If the above isn't checked, you could try selecting *Screen timeout* and change the minutes. Try changing it to 15 seconds, then set it aside and see if the screen goes off after fifteen seconds. It might be that for some reason the timeout is no longer registering and resetting it might get it to time out again.
One other thing. If you have some kind of a screen protector film on it make sure it is clean and has no scratches in it or moisture under it. If the screen thinks it's being touched it won't time out.
If neither of the above does it, I'm at a loss to think of what else it might be. Good luck.
Feb 13, 2015 | Samsung Galaxy S5
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
The Tv screen stays bleu and switching from videio to TV dos not help
Reset the TV to its factory settings. Unplut it from AC mains, and replut it after some seconds.
Apr 11, 2012 | Televison & Video
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
Problem with canon a420 digicam
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Note that your camera will not be able to take 15 second exposures, as per the above "fix". Instead, place the camera in manual mode, turn off the flash, and take the exposures in a darkened room. This should give you a couple seconds, just enough time to open the battery door while the red and yellow lights are flashing.
Sep 21, 2009 | Canon PowerShot A420 Digital Camera
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Mitsubishi TV
Someone turned on the closed caption my friend. You will have to turn it off with the remote most likely. Since you thought we are fortune tellers and did not leave a model number, we cannot instruct you on how this is done. Most likely there will be a button on the remote that says captions or CC. Good Luck
Oct 04, 2007 | Televison & Video
DVD player froze, now only turns off
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Jan 13, 2007 | Philips DVP642 DVD Player
Dell E173FP 17" LCD Monitor Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
