Question about Janome 1600P-DB Mechanical Sewing Machine
I am trying to do freemotion quilting and continue to break needles.
First Zenqi, that you are not telling the appropriate size needle. Or the type of needle. The first is the "TOPSTITCH" needle is the best for both piecing and quilting. The Topstitch needle has the best GROVE, EYE and BEVELING on both sides of the eye. To use the Superior Thread Titanium Coated Topstitch needle is better because it stays sharp for 40-60 hours.
The size of the needle is needed for the size of the thread. The thread needs to be inside the grove so it will not touch the fabric. If it touches the fabric it will wear out the thread. For 1" of the thread it goes back and forth throught the eye of the needle over 60 times. This is why the thread would get worn out if it could touch the fabric.
Your secound paragraph is correct. The other reasons that was not asked was the type of hopping foot, and dog feet down or covered.
For all of you people go to Superiorthreads.com/education
You will learn a ton of smart information to help you.
Steven Rice
Posted on Nov 05, 2009
  • 208 Answers
Could be several things. First, make sure that you are using an appropriate size needle, not too big, and that it is inserted with correct orientation.
Make sure that as you move the fabric, that your movements do not cause the needle to bend as it penetrates the fabric. If the fabric is pulled as the needle is penetrating the fabric, it causes the needle to bend and strike the plate or be struck by the hook. Smooth, fluid motion at a moderate to high speed makes for good freemotion sewing.
If you still break needles, the hook may be too close to the needle; an adjustment to be made by a technician.
Posted on Oct 08, 2009
I am quilting and the thread keeps breaking. What is the problem?
Not sure if you are piecing or trying to free motion quilt. If FMQ, try using an Embroidery needle (it has a groove in the shaft that helps protect the thread) or a Topstitch needle. Make sure the thread is not too thick for the needle's eye. Check to make sure the upper and lower tensions are not too tight. You might try changing brand/type of thread.
Here's a needle guide:
SCHMETZ Household Needle Chart
Or review suggestions for breaking thread here:
Why is my thread breaking
Hope this helps!
May 20, 2015 | Sewing Machines
Pfaff quilt expression 4 0
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 23, 2013 | Sewing Machines
Needles keep breaking when i quilt, its like they dont fit or too long quilt expression 4.0
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Jan 09, 2013 | Sewing Machines
Started machine quilting; first pass went just fine, rolled up quilted portion, then started machine again but the bobbin thread broke and continues to break. Took out bobbin, reset it in case, etc. N
from what you said about the bobbin thread continues to break
check for burrs in the following area--even the smallest burr can cause problems
bobbin
bobbin case
needle plate
needle could be damaged
or bad thread
Feb 10, 2012 | Juki TL-98Q
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
The needle thread on my bernina minimatic keeps breaking.
There is special thread for denim/jeans. It usually comes in shades of brown. It's a little heavier and might help with the breakage. You might also want to try a little less tension. I assume you already have a Schmetz denim needle?
Apr 06, 2009 | Bernina Virtuosa 160
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Thread breaking
I HAVE THE SAME PROBLEM WITH THREAD BREAKING. HAVE TRIED EVERYTHING. FINALLY I GOT SOME UPHOLSTERY THREAD AND IT SEAMS TO WORK MUCH BETTER. NOW i AM HAVING TROUBLE FINDING THE NEEDLES FOR THIS MACHINE. NOT HAPPY WITH MACHINE AT ALL
Dec 09, 2007 | Janome 1600P-DB Mechanical Sewing Machine
Janome 1600P-DB Mechanical Sewing Machine Logo
257 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
