Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Electric coil sounded like transformer blew and started on fire and now oven won't heat up.
    President:
  • 1,304 Answers
Its probaly a bad element i replace it
bake elkement
Posted on Oct 08, 2009
Yesterday when i tried to turn on my electric oven it made a pop sound and either the fan nor the spark igntition work.
well,electric ovens dont have a spark ignition,your heating element blew out,replace it
Jun 20, 2015 | Ovens
We replaced my ge gas oven ignightor but the gas is building up and when its heating to the right temp the door blosw open
sounds like the gas valve is leaking un plug the range and use a soapy water to find the leak
Jun 26, 2014 | GE Ovens
Frigidaire oven won't heat past 355
Contact a professional to have the unit diagnosed for repairs. Sounds like the heating elements are either faulty or the main control board won't allow the unit to heat up correctly.
Sep 05, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a LG LRE30453SW Electric Range and the relay pcb keeps going bad. I get an F7 error when starting the oven. The first time I noticed the black line in, from the power terminal, to the relay pcb was...
First, check the 220v line and breakers are properly grounded and that you are getting a constant 220v at the plug. Then you will need to check the transformer on the unit.To test a transformer you need to know what type of transformer it is first. There is a step up transformer which steps the voltage up and a step down transformer which steps the voltage down.
You will still test the transformers the same way for step up and step down transformers. If it is a step up transformer apply the incoming power to the transformer or plug it up. Now take your multimeter and place it on the AC volt scale and test the voltage if the voltage on the data plate says the transformer should step up to 220 volts and it doesn't then your transformer is bad.
Now repeat the same steps for a step down transformer. Plug up the incoming or primary power and test voltage on the outcoming or secondary side the voltage should step down to the proper value. If you don't read any voltage on the secondary or outgoing side then the transformer is bad.
To read the voltage place the two meter leads on the secondary side, or the side you will plug your equipment into. If the secondary side is an outlet then place the two meter leads into the top two slots in the plug and read voltage. You also want to make sure the incoming power is working as well. Otherwise you will be reading a bad reading every time.
If all that looks good, then you will need to replace the control board. Here is a link to the parts for your range.
Regards,Richard
Dec 08, 2011 | Ovens
Oven won't heat
hi, sounds like the heating element
Mar 07, 2010 | AEG U3100-4 Electric Double Oven
Had set my Magic Chef oven on self-cleaning mode and about 30 minutes into the cleaning cycle there was a pop and a flash. I suppose something has shorted out because the controls are no longer working. Is...
Yes the oven is able to be repaired depending on what popped. You will need to get at the control panel which is located at the top of the oven behind the burners. You may have to remove the rear panel to gain access. Also you can follow the outlet plug to the transformer. IT sounds like you lost a fuse. If the fuse blew on the control board, then you will need to look for a short somewhere, if it blew at the transformer, then you just need to replace the fuse
Jan 11, 2010 | Ovens
Bottom oven failed blew fuse when reset only bottom oven not working
It sounds as if your bottom oven heating element has 'blown'. You will need to replace the heating element.
Dec 26, 2009 | New World E90DOa Electric Double Oven
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
125 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
