I HAVE A SHARP AR 250 DIGITAL IMAGER WITH A FAULT CODE OF H4-01 I NEED TO CLEAR THE FAULT SO I CAN CONTINUE TO USE THE COPIER. CAN YOU HELP ME? THE COPIER WAS OUT OF TONER AND I REFILLED THE TONER, BUT HAVE NOT BEEN ABLE TO CLEAR THE FAULT CODE.
    Guru:
  • 389 Answers
Regrettably, came out of building block fuzer
H4 01 The fusing unit doesn't heat up
The Possible faults:
- no contact in block fuzer
- Papersensordefective in the fusing unit
- not faithfull signal of the controller of the direct current
Offer you to apply to service Sharp
Posted on Oct 08, 2009
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Pls help for sharp copier AR-5316 error code 2-H
H2 signal is thermistor open
check the harness and the connector between the thermistor and the PWB use TC 14 to clear the self diagnostic display.
Oct 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-285 Error Code ''U2-00'' What does that code mean and can I fix it locally?
A U2-00 is an internal error code from the main processing board's EEPROM (the chip that stores your configuration choices, the copier's serial number, etc.) It can be a faulty EEPROM but most likely the copier took a power hit/glitch and the fault needs to be reset.
To clear the fault make sure the copier is in Copy mode, then press the 'P' key, then the 'Interrupt' key, then the Clear (C) key, then the 'Interrupt' key. This will enter the machine into simulation mode.
Now enter the number 16 and press start. The machine may also ask you to confirm your choice or you may have an 'execute' key on the LCD screen.
Once the fault has been cleared the machine should reboot. If it doesn't, press the 'CA' (clear all) button and the machine should reboot.
If the U2 code persists, you need to call a repair technician to facilitate repairs.
Sep 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5320e error code U2
please press these buttons in order #, interrupt,C , interrupt.
when display goes off enter 14 then start button it is ok
Dec 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
155 people viewed this question
jasbo
jasbo
