Question about Refrigerators
Control Board I have a refrigerator Emerson i need a control board for it the model number is EMRT16612 serial 3014301050 110v Thanks Meredith Isei
SOURCE: Whripool Side by Side Control Board part Number 2304095
I had a part to go out on my fridge and can not find it anywhere, my freezer stopped working lost all of my food. There was no place locally that I could purchase the part........What is it coming to
Posted on May 19, 2008
tech master
  • 120 Answers
SOURCE: Sears Kenmore Elite Refrigerator model
need model number even though it says kenmore we need to know the model will tell us the maufacturer but start by checking voltage at the outlet to see if you have proper ground
Posted on Oct 17, 2008
SOURCE: Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Posted on Apr 06, 2009
  • 462 Answers
SOURCE: Defrost Heater or Main Control Board, Which one is at fault?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To answer your question I know of no reason the electronic type of board would cause the heater to go out unless the defrost thermostat (or sensor) and board stuck in the defrost possession and did not stop the heater. Any time you replace the board and have had a defrost problem a check of the heater will either confirm or eliminate it but the defrost sensor should be replaced if the board is being blamed for non defrost. I cant rule out 100% that a bad board will not cause a heater problem but the high 99% range is most likely. If you have a volt ohm meter and can find the heater circuit on your board and the freezer has been running down to correct temp you can check the defrost circuit by ohming it out. Lower resistance of 10 to 60 ohms is common. Anything higher will require ohming the heater out directly and the defrost thermostat will be open if the temperature is above the stats range.
Common to all self defrosting refrigerators / freezers is the need to move air around to pickup heat inside the compartment. Common to all frost free refrigeration to maintain this feature are 3 items:
1 and initiator (defrost timer or circuit board),
2 A heat source for defrost (Usually an electric heat element but can be other types of heat sources)
3 A safety limit to stop the heat source, leaving it warm enough to defrost and keep the heat contained where it will not affect the compartment advisedly. In a standard type defrost (non - electronic) it is called a thermostat. In an electronic board defrost it is called a sensor.
The defrost timer / or board will never be in the Freezer. Other than that it could be in the refrigerator section behind a plastic cover or metal cover on the back outside. It could also be under Neath the front corners or center of the front kick plate.
A timer you can turn the cam clock wise till it clicks. A board will depend on the manufacturer as to how to send into defrost for a test. A sensor on the defrost type board may be required to by-pass into defrost or test mode.
The freezer section has the only cooling coil. It sounds like it is blocked with frost and thus won’t let the air circulate from freezer to refrigerator.
There is a defrost timer, (or board), a defrost heater, and a defrost safety thermostat. Any One of these or a combination of 2 can be your problem. If you have a energy efficient model that has electronic controls then you will have a board. The procedures for checking the circuit on a board vary by manufacturer of the board used and manufacturer of the appliance.
The defrost heater always has resistance and is attached to the freezer coil.
The defrost thermostat is also attached to the heater electrically, unless it is an electronic sensor type. Sensor types have a range of resistance that needs to be known to check and varies slightly with the temperature of the sensor.
If I haven't lost you here you maybe equipped with the life experiences that will allow you to do most of these checks. If its over your understanding I recommend you contact a reliable technician..
Posted on Apr 17, 2009
  • 56 Answers
SOURCE: Replaced control board Kitchenaid KBFA25erss refrigerator
should be on the serial plate
Posted on Jul 03, 2009
Control board id
The control board Id will be found on the model and serial number tag. The model tag can be found inside the refrigerator section on the left, right, or ceiling of the fridge.
Mar 13, 2015 | Maytag Refrigerators
Locate control board in frigidaire refride
Hi Friend, I am happy to assist you!
I understand you are seeking the location of the control board in your Frigidaire refrigerator. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the left or right side wall. With this information I can provide you the correct location. Thank you! - Z
Jul 06, 2014 | Frigidaire Refrigerators
Main control board
Kenmore model number looks like this 795.51313012 90364894-0494-4d01-a2bd-9abc6a90a2c6.jpg
I am here should you need me, Thanks John Tripp Appliance 911
Apr 23, 2014 | Kenmore Refrigerators
Frigidaire Refrig model GLHS36EJSB has a constant beep with no lights on the temperature section on the control board. I have a feeling the board is bad. Completed reset for 15+ minutes of unplugging the...
Good Afternoon mustang2060, thank you for allowing me to assist you! Based on the symptoms you are describing, it appears you are possibly correct. Sounds like the issue lies with the control board, however I recommend a proper diagnosis to pinpoint the exact problem to be certain and to reduce the risk of unnecessary parts. I will be more than happy to provide you the part number of the control board of your refrigerator, GLHS36EJSB. However, may I please have the last digit of the model number (in most cases it is a number) to provide you the correct information. The serial tag is typically located in the left or right side of the wall. Thank you!
Aug 24, 2013 | Frigidaire Gallery GLHS36EJSB Stainless...
GE profile refrigerator control board #
What is the model number of the unit?
Nov 11, 2012 | GE Refrigerators
Replace motherboard for gsh25vgrbcc
Your refrigerator uses the common GE WR55X10942 control board. On most models you can just swap out the control boards. Some models require a few additional steps, you will have to check your serial number to see if that applies to your model (see instruction sheet included with the control board).
First unplug the refrigerator.
On the back of the refrigerator, there is a panel. Remove the screws and the panel cover.
Unplug wires from the old control board (note where the wires go), and plug them into the new control board.
Plug refrigerator back in and test out.
For more detailed instructions, and pictures click the link below.
How to replace WR55X10942 control board
Jan 25, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Brought the GE WR55X10942 Refrigerator Main Control Board, and I am getting ready to install it, it saids to eliminate thermistor wire in pin 2 of J1 connector for any encoder models that starts with a...
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Jul 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
I have a GE side by side fridge. First the water would stop working intermittently. Then the ice and water stopped all together. Now on top of that its making a clicking noise and the freezer works for...
Your model needs attention soon to prevent damage to the control board. Something simple as a fan going bad will cause a chain reaction on your model. Let me know if you would like my assistance or your you would like to call in a technician. I can help you repair from here or my site. Thanks, Sea Breeze
Nov 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Model #: GSS25JFMC WW. during the pass two days my refrigerator has stopped cooling.
Your refrigerator has a control board on the back. This is likely the problem. Another possible problem is the start relay and capacitor on the compressor. To examine the board unplug refrigerator and remove cover over the board. Remove so you can examine both sides for burn marks or signs of heat on the black relays. Visit my site and enter the model or part number into the search feature You will also see a picture of this board on my web page.
Board part number WR55X10656 main control board. Thanks, Sea Breeze
Jun 30, 2009 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
