Question about LG enV VX9900 Cellular Phone
Can you help activate wap and mms settings on a lg voyager vx10000 flashed to metro pcs?
  • 17,970 Answers
LG VX10000 Tutorial with WAP and MMS (from howardforums.com)
I figured this out, as I'm sure many others have already, so I'm not taking credit for this one, the real credit goes out to the ones who made the original breakthroughs in these areas like berry_lthird and those who helped him to make the all important VX9900 discovery and so on.
Use the VX9900 dll for everything and flash the VX10000 just like it was an EnV until you get to NV editing. Do everything the same and edit all the tabs mentioned in the VX9900 tutorial EXCEPT the WAP TAB! Editing the info in the wap tab will lead you to have this problem (thank god I figured my way out of it, also in the thread).
NV Write to the phone. Once it's all done, close LGDownload and open Bitpim. You may need to get the newest version (1.0.5 ) so that it supports the VX10000 for convenience. Click find a phone, it should find the VX10000. Click Filesystem in the left column. (If it's not there click View and View Filesystem and it will appear) Navigate your way to Brwoser>Settings>fileDB. Save fileDB to your computer. Use a hex editor like XV132 to change the second to last character in the file from a 0 to a 1 and save it. If you don't know what you are doing you may want to save a copy of the original on your computer. Overwrite the fileDB in the filesystem with the editted one.
Now on the phone press ##PROGRAM10000 and then press Send, then 000000. I have only confirmed that this works from the inside, never tried from the outside. Go to Wap settings, and change everything according to the VX9900 tutorial like it was in NV Edit. Aftrer you are done power cycle the phone and you should be up and running if it is already active on Cricket.
If you activate it after you do all this you will have to go into the Service Programming menu and change the username again, but at least you already unlocked the ability to edit in that menu.
Here's the VX9900 tutorial for reference and quick access. Thanks again berry_lthird. And you can all thank randomwit for inspiring me to write this tutorial (I forgot how, but his treo cables probably had something to do with it).
Good luck.
Posted on Oct 07, 2009
LG Voyager Locked
To enter unlock code for LG, You need to insert sim card from network which is ... You can get Your LG VX10000 Voyager IMEI number by typing *#06# or after ... are locking devices on carriers demand, so when you unlock LG VX10000 ... sim-unlock.net/simlock/LG/VX10000 Voyager/ sim-unlock.net/simlock/LG/VX10000%20Voyager/
hope this helps
Feb 08, 2012 | LG VOYAGER VX10000 Cellular Phone
Can not connect to internet or send picture messages
Call your Service Provider
Ask for the settings of MMS and GPRS for your mobile.
They will send the settings as text messages.
You will receive two messages,when you are received them save them and turn your mobile off for
3 minutes then turn it on again.
The (INTERNET) service and the picture messages (MMS) are activated.
Jun 13, 2011 | LG VOYAGER VX10000 Cellular Phone
How to communicate or activate my gprs?
hello beljohn,
i have some tips for your question hope this helps
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
Apr 14, 2011 | Nokia C3 Cell Phone
NEED HELP PROGRAMMING MY LG VX 10000 VOYAGER WITH METRO PCS WAP AND MMS. NEED CODES AND HELP ASAP!! PLEASE!!
Go to this thread on Howard Forums: http://www.howardforums.com/showthread.php/1445736-Web-And-MMS-Settings-Check-Here-First....
If you cannot find detailed instructions for your phone, or the general ones do not work, you can make a quick post and someone will help you. Howard Forums is a great resource to learn more about your phone.
If this helped, please help me by giving a few thumbs up!
Mar 03, 2011 | LG VOYAGER VX10000 Cellular Phone
I had it flashed with metro pcs and now i cant recieve or send pic messages
metro pcs doesnt allow to send or recieve pic mssages or go on the web.its part of the metro pcs system.
Oct 08, 2009 | LG VOYAGER VX10000 Cellular Phone
Flashing motorola Q9c to metro pcs is there a program to flash my cdma motorola Q9c to metro pcs service with internet phone mms and sms messaging
i master reset my motorola q9c its flashed to metro i lost all setting when i get ready to get on internet it says wrong login info
Jun 16, 2009 | Audiovox PPC 6700
Verizons LG Voyager fully flashed to cricket but internet not wor
If a dealer is knowedgeable enough to claim that an LG Voyager is fully flashed, then he should know that he must activate it on its intended phone #, at the time it is flashed. Otherwise, the web will not work. This is known and common problem with the LG Voyager, and if you are able to fully flash this phone, you're aware of this problem and know how to deal with it.
Sound like this dealer did not do the flashing themselves, and were not properly trained on how to activate and refresh wap settings on a Voyager at the time of sale.
The LG Voyager must already be activated on its intended phone #, at the time the phone is flashed. This is unique to the Voyager. None of the other verizon LG phones have this requirement.
The reason is because the simple act of dialing *228, or manually programming the phone#, erases the WAP settings on this particular LG phone. Specifically, it is the WAP Gateway that is erased, and this can only be fixed by somebody who knows how to flash this phone.
This is the only verizon LG phone that will automatically erase its WAP Gateway when the phone # is programmed into it, by dialing *228.
If your Voyager is working, DO NOT DIAL *228, EVER, Keep in mind, if you call cricket for any type of billing/tech support on your account, they will tell you that you must dial *228. DO NOT DIAL *228, if you have an LG Voyager. *228 is similar to restarting your computer. It's good advice, but is usually not required.
If you are going to pay somebody to fully-flash your phone, that person should offer, even require, that they transfer service to your phone for you, at the time it is flashed. The only way to know for sure your phone was properly flashed, is to test out the web and picture messaging features, when your phone is done being flashed. I *always* test out the web browser, and incoming/outgoing picture messaging, before I consider a customer's phone to be ready.
There's is no 24hr waiting period for web/picture messaging. Basically, if it works for voice/text, there is nothing to keep web/pix from working immediately. A dealer or experiened flasher has the tools/resources to make sure the customer's account has the proper features for web/pix to work.
My last piece of advice, is that you do not have to be paying for web, in order to use the web browser on a fully-flashed cricket phone. That is right, cricket offers free web-portal access to Cricket's homepage, which doesn't include much, but does give me a page or two to load, to make sure the phone is working correctly. If you have picture messaging, you should be able to visit this page, even if you don't have web on your account: http://wap.cricket.motricity.com, and http://search.wap.mycricket.com.
There is an easy way to test if your Voyager has simply erased its wap gateway. If you can send and receive picture messages, but just cannot use the browser, then your phone is flashed properly, but needs to have its wap gateway settings refreshed. You can verify this by visiting http://www.accuweather.com, because if picture messaging works, accuweather.com will load in the browser as well. This is because accuweather.com is unique, it's the *only* website that will work on a cricket phone, without going through Cricket's wap gateway.
Well, hope this help and is not too much information. I will say, though, everything I've written is 100% accurate. I have been doing "full flashes" on Cricket phones for almost 3 years, before most people even knew you could do basic flashes. The best resource on the internet for learning about the capabilities of flashed Cricket phones is at howardforums.com, in the Cricket subforum, located here: http://www.howardforums.com/forumdisplay.php?f=336
Jay
Denver, CO
aka beezlewaxin
PS - I cannot wait for the day when my answer is proven wrong, which can only happen when somebody figures out how to flash the Voyager so that *228 is safe, and no longer erases the wap gateway. Tougher problems have been solved, maybe someday this one will be solved too. Until that happens, DO NOT DIAL *228 IF YOUR VOYAGER IS WORKING!!! can't say that enough....
Mar 28, 2009 | LG VOYAGER VX10000 Cellular Phone
Phone not ringing?
go to settings then phone settings then voice commands then call alert and put ring only
Nov 01, 2008 | LG VOYAGER VX10000 Cellular Phone
LG enV VX9900 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
