Question about Belkin (F5D7231-4) Wireless Router
My router is not security enabled. How can I go in and change the settings?
    Problem Solver:
  • 10 Answers
In your web browser type in www.192.168.2.1
When it asks for a password press enter or try admin if that doesn't work. When you log in look for a section that says wireless security section. It will ask whether you want WEP or WPA. Choose WPA and set the password.
Posted on Oct 07, 2009
Thank it works but you dont need the www.
Posted on Oct 11, 2009
3 Suggested Answers
shindou
  • 70 Answers
SOURCE: How to set up security enabled facility
You can try these steps to configure the BR6216MG router for wireless security:
1. connect a computer to the router's numbered port.
2. launch a browser and type in 192.168.2.1, user name is admin and the password is 1234 (unless you changed it, if you do, then use that password)
3. Once you are in, click on wireless then click on Security.
4. Under Security, you can set it to either WEP or WPA. But for ease of use, I suggest you use WEP.
5. Set it to WEP then 64 bit for the key length.
6. You can then select ASCII or hex (that depends if your wireless adapter support both or one only). For hex, you can only use the letters A-F and numbers 0-9. For ascii, you can use characters, letters and numbers.
7. Set the default key. Only the key you select it in the "Default key" will take effect.
8.You can now fill the selected text box with the password that you want. Then click Apply.
If you have questions, just ask me then I'll answer your question as soon as I can.
Posted on May 12, 2008
govinda123
  • 2263 Answers
SOURCE: how do I enable wireless security on router
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Jun 25, 2010
How to secure my pass word
Take a look on these point for password security :
Change your Default Password , Set up a security key for your wireless router, Try to priorities WPA than WEP for more protection, Disable your remote administration setting and Enable your router Firewall and MAC Filter. Try Security set-up http://www.ehow.com/how_4829036_secure-belkin-wireless-router.html and Router Support for more help.
May 29, 2014 | Belkin Basic Wireless Router
Set up security
If you know the default username and password then you can login after reset the router. Reset the router using reset button. To get manual you can visit router manufacturer website.
If you want to set security then you can do the following steps:
->Change Default Administrator Passwords (and Usernames)
->Turn on (Compatible) WPA / WEP Encryption
->Change the Default SSID
->Enable MAC Address Filtering
->Disable SSID Broadcast
->Do Not Auto-Connect to Open Wi-Fi Networks
->Assign Static IP Addresses to Devices
->Enable Firewalls On Each Computer and the Router
->Position the Router or Access Point Safely
->Turn Off the Network During Extended Periods of Non-Use
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Nov 08, 2012 | Computers & Internet
How do i reset my wps orange light stays on no internet
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 23, 2010 | Belkin (F5D7231-4) Wireless Router
How do I secure my D-Link WBR-1310 wireless router?
You can follow these steps in enabling wireless security on your router and do this steps using a computer wired to the router since once you save the settings your wireless network will be secure.<br /><br />1) Open the internet browser and type the address 192.168.0.1 to login to the router. The default username is "admin" and leave the password box empty.<br />2) Click "Wireless Settings" on the left side.<br />3) Select the Security Mode ,Enable WEP Security.<br />4) Select the Authentication ,Shared Key.<br />5) Select the WEP Encryption , either 64-bit or 128-bit.<br />6) Select the Key Type ,HEX (only A-F and 0-9 number allowed) or ASCII (all number and character allowed).<br />7) Enter a WEP key as your security password to login to your wireless later.<br />8) Press Save Settings to save all settings changed. Reboot the router.<br /><br />
Aug 24, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How do I enable wireless security on router
Jun 25, 2010 | D-Link DIR-615 Wireless Router
How do I make my router access secure?
look on the bottom of your router there is an ip adress, go to it and enter the password located on the same sticker the ip adress is on. Once you access this page you are in the router's setting, go to security and select the settings you want.
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot get the roku box to work the signal comes up with a lock on it did work exallent until christmas how do i get the signal un locked
When you have the wireless signal with a lock it indicates that your wireless network is secured.
Your wireless network has a security key enabled
Access the router page
Go to the wireless settings or WAN settings
Check what is the security mode(WEP/WPA)
If WEP check which Key is selected(key1or2or3or4)
If you are not able to find the key create a new one
If you change the key here ensure that it is updated on the wireless computers as well
Jan 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Securing router
hi,
Go to your network properties and at TCP/IP go to its properties.
go inside "advance" and then go inside the "Options menu".
Now enable the TCP/IP filtering and set to "permit only" enter the TCP/IP numbers of the workstation that you have... apply it to the three boxes (TCP, UDP and IP Protocols)
Hope this helps... Goodluck!!!
Mar 05, 2008 | Linksys Wireless-G Broadband Router
Belkin (F5D7231-4) Wireless Router Logo
1,545 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
