Question about Motorola Mobility H710 Bluetooth Headset
How do you reset the motorola h710 bluetooth headset and pair it with your phone???
zohail
  • 1223 Answers
SOURCE: have motorola h710 bluetooth headset and no
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Posted on May 03, 2009
zohail
  • 1223 Answers
SOURCE: how do i sync motorola h710 bluetooth headset to my cell phone
here is the procedure kindly rate me well !
http://www.motorola.com/staticfiles/Support/Mobile%20Phones%20Accessories/H710/US-EN/_Documents/Static%20Files/H710_QSG.pdf
  • 3 Answers
SOURCE: My H710 headset will not enter pairing mode.
Try this- first,make sure on your phone, that you have checked that bluetooth is on. You do not need to also check the box to make visible with other devices.
Then-try this, (I got mine to work (I had same problem). On headset, close boom, hold center button (and it turns pink). then, while keeping center button depressed, open boom- light remains pink. Then look on phone, and hit Add new device-- and bingo, it should be recognized now!! You'll be asked if u want to pair w/ Motorola-- and led through the process--follow those steps.
I had tried similar earlier, but the trick was to keep the button depressed, and then open the boom. I can't quite remember if I kept button depresed until I also pressed Add new device on phone or just until after opening the boom and the light stayed on ... Sorry I can't be exact; I was too excited. Hope this helps you get yours working!
Posted on Jan 02, 2010
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do I get my Motorola Elite Flip bluetooth headset to stop echoing on the other end?
    Alesia-
    Try a reset: ELITE FLIP Reset to factory default
    Try changing setting: MotoSpeak 3 0 Noise Cancellation settings
    What device are you connected to? I see other have reported after an android update on NON-Moto Devices: Headset echo problems after Android 4 3 update Verizon Wireless Community
    Mark
    Motorola Support
    Posted on Feb 11, 2015
    Motorola H710 I can not hear
    You can try to delete the H710 out of your HTC's history. Then power the phone off and on again. Then go back through the pairing process to see if it improves. You can also try to reset the headset.
    Jul 09, 2014 | Motorola Mobility H710 Bluetooth Headset
    I have a brand new Motorola H710 Bluetooth headset. My previous headset was also this model so I know how they work. I paired it with my Razr and I can hear people talking but they can't hear me. Is...
    Hello Steve. This is a common problem with the H710, with no available explanation. I recommend that you take the bluetooth and your phone into the phone store where you bought the bluetooth and have the technician there check it out. Joe
    Thanks for choosing FIxya!
    Nov 18, 2010 | Motorola Mobility H710 Bluetooth Headset
    How to connect my motorola H710 bluetooth with my mobile
    You must put it in pairing mode. If it has not been paired to other phones, just open its boom. After a while the indicator LED will be steady blue. Otherwise, if it has been previously paired to other devices, make sure the bluetooth radio of those devices are turned off. Then, open the boom and, as the headset won't find any devices already paired around, it will enter pairing mode automatically (again, indicated by the steady blue LED).
    Once your headset is in pairing mode, make your phone's bluetooth application search for new devices. After a while, the H710 will show on screen. Select it and command it to proceed. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
    By the way, if your headset's user guide happens to be missing, you can download it from this location;
    Hope you are able to sort your problems out.
    Cheers! Carlos
    May 09, 2010 | Motorola Mobility H710 Bluetooth Headset
    Need instructions on how to pair bluetooth motorola H710 with blackberry curve
    Be sure the the headset in in 'Pairing' mode.
    When in pairing mode, the light should be flashing red and blue or have a steady blue.
    The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
    Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
    Dec 25, 2009 | Motorola Mobility H710 Bluetooth Headset
    How do I add a 2nd phone to motorola bluetooth headset h710?
    after you connect one phone. go into phone settings and turn off bluetooth. go to second phone open bluetooth options. not put your h710 into pairing mode. once paired, go back to original phone, turn bluetooth setting back on, and both devices are now paired.
    Jul 03, 2009 | Motorola Mobility H710 Bluetooth Headset
    The phone will read that it is paired with a Motorola H715, although the packaging identifies the bluetooth as an H710, but the phone never really pairs and will not work with this bluetooth. I have...
    check out this manual for pairing up info
    please rate me well for help !
    Apr 18, 2009 | Motorola Mobility H710 Bluetooth Headset
    Motorola H710 setup
    try video instructions on www.HandBookLive.com under Electronics category. There are video chapters on turning on Bluetooth features and pairing for Nokai and Motorola phones for H710 headset, also chapters on using Bluetooth itself.
    Feb 14, 2009 | Motorola Mobility H710 Bluetooth Headset
    Pairing my motorola H710 to my Blackberry Storm phone
    try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
    Also make sure the battery on theheadset is charged before doing this.
    The passkey will be 0000, four zeros.
    Dec 30, 2008 | Motorola Mobility H710 Bluetooth Headset
    Motorola Mobility H710 Bluetooth Headset Logo
    1,647 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
