Question about Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher
No lights no power
Obviously some sort of electrical problem. I switched the breaker on and off -- didn't help.
Last night the dishwasher worked. Today it doesn't.
Any ideas?
  • 4 more comments
  • janehooker Aug 28, 2008
    I have the same problem. called the place where it was bought ,they charged me 135.00 said it was a latch problem because its plastic. that was a week ago. today same problem. wont start. they are coming friday again to look at it.
  • leannsmith57 Oct 03, 2008
    My dishwasher is not starting up. I think someone tried to help and pushed too many buttons. Is there a reset button?? Already tried turning the breaker on and off, nothing changed. One of the buttons is still lit up, but it doesn't change any of the functions.
  • russelld Nov 21, 2008
    no lights on control panel, checked breaker and breaker not tripped. Dishwasher is only 1 year old.
  • jessc1333 Jan 19, 2009
    Twice we've lost "power" to the unit and holding down the power button would not reset it. We've switched off the breaker and back on again but still it doesn't help. It will eventually come back on its own and we're not sure why. Last night we had a different but similar problem where we could not change any of the settings or start a load. It's as if the buttons are frozen. After trying all of the breaker flipping, opening and closing, and holding down buttons we gave up. This morning I got up and it was back to normal and I was able to run a load. Very frustrating!!
  • pgziegler Jan 25, 2009
    Same problem - no lights & not working.  Happened last week and came back on on it's own.  2 days now and it still has not come on.  Contacting store on Monday.  Model EIDW6015GS
  • Michele Molek Apr 12, 2009
    I have been having the same problem. The first time, it was off for three days. When I finally called Electrolux, the darn thing magically came back on while I was on the phone. The tech person told me that if it happened again, I should hold my hand over the control panel for 30 seconds to reset it. Well it happened again today, and I held my hand over it for 30 seconds and even longer a couple times, but it did not help. Of couse it's a holiday and the customer support line is not open. It definately sounds like a design flaw to me. I'm very frustrated. Oh, I hate my Electrolux microwave too (love the range though).
Check on/off switch. Ours was left on for an extended time and now there is no lights no power. When we do turn it on it shuts of the power box. Husband checked on/off switch and it is burnt out. waiting for price on new switch.
Posted on Sep 01, 2008
I had the same problem, but husband just unplugged the machine and plugged it back in and now its working again. dont know why, but that worked. good luck
Posted on Jul 18, 2008
Why has my dishwasher stopped working completely?,
Sounds like it isn't getting power. Check the circuit breaker that controls the circuit the dishwasher is wired into.
Aug 31, 2014 | Whirlpool 24 in. DU915PWP Built-in...
Kitchenaid Dishwasher thermal fuse keeps blowing
if your fuse is blowing often i would suggest you to move your washer to a different place and try a different plug point.
there may be some fault with your power.
try to sort it out step by step.
thank you
Sep 17, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Bosch SHY66C
maby kinked hose
Jan 31, 2008 | Dishwashers
Install hunter fan model 28714 last night worked all night and the morning when came home of pulled and checked power okay
Make sure that the circuit breaker didn't trip, if it's a new device, it could be that just too many things are on the same circuit.
Jun 01, 2011 | Hunter Ceiling Fans Individual...
We have a GE profile dishwasher. It worked fine last night. Tonight we loaded it and closed the door. Its like it dosent power up.
If your dishwasher doesn't work at all, check these: Power from the house Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to re
Oct 11, 2009 | Dishwashers
Dishwasher won't start. Electrical breaker is on.
Sounds like your door switch, You can try to adjust this usually it is just two screws on the unit where the latch is.
Sep 29, 2009 | Electrolux EW1000i Front Load Washer
Dishwasher will not turn on. Last night I started
You need to measure with a voltmeter for 115 Volts at the electrical box under the washer front. Breakers can fail, yet look ok. This will check the breaker output and all of the wiring in between. There may also be a local circuit breaker that tripped.
Aug 18, 2009 | Dishwashers
Maytag quiet series 300 problem model MDBH955AWB Set washer to run on Delay last night. All lights were go. Has worked in the past. It didn't run and now, no lights, and doesn't operate. No problem...
same problem...seems this appliance is a piece of ****....i have read nothing but bad things about it....i have the choice to pay 250 to repair it...or replace it....easy choice....
Jun 19, 2008 | Dishwashers
Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Electrolux Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
662 people viewed this question
Top Electrolux Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
