Question about Sony Cyber-shot DSC-W70 Digital Camera
When i turn my camera on the lens keeps going in and out and then stops when it like half way out and a message on the screen says to turn power off an on again. But that doesn't do anything, it will turn off and then do the same thing when turned on. What's wrong?
  • 300 Answers
Hi!
The focus is stuck - could be sand or something.
I work in a Sony service center and repair these every day. It will be quite expensive at Sony service center so I would recommend you contact a local repair shop.
Tom
Posted on Oct 09, 2009
I HAVE A SONY DIGITAL CAMERA DSC T-20 AND HAVING AN ERROR MESSAGE E:61:10 PLEASE SEND ME HOW I CAN SOLVE THIS PROB LEM
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
I hope it will be Helpful for you.
Thanks and keep Using FixYa
Mar 16, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
E:61:00 on sony cybershot camera
To solve this
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
Mar 02, 2011 | Sony Cyber-Shot DSC-F828 Digital Camera
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Olympus FE 270 Digital camera lens, screen, etc not working
Hi!
Hi!
The focus is stuck. Could be sand, dirt or something in the focus gears - well known problem for these lens. Contact your local Olympus service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
Tom
Jul 03, 2009 | Cameras
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Lens stuck half open
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Apr 26, 2009 | Olympus Stylus 840 Digital Camera
When I turn my Sony Cybershot 7.2 mega pixel camera on, the lens keeps going in and out and the message "Turn the Power on and off again" shows up on the LCD screen. When I turn the power off and on again,...
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Dec 06, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Lens Jam
Did u ever get this problem sorted, as I am having the same issue now. But mine just did it one day after turning it on
Jul 27, 2006 | Canon PowerShot G6 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
166 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
