Sony KDF-E55A20 55 in. LCD Television
Problem for Sony KDF-E55A20 55 in. LCD Television
My scean has vertical color
By hworstell on Oct 07, 2009
My scean has vertical color bars on it and no sound. the remot only turns the tv onb and off. on other remote functioon does anything.
Solution #1
posted on Oct 12, 2009
Not Rated)
cyndi25
Rank: Apprentice
Rating: 0%, 0 votes
Go to the back of your owners manual and find out how to do a system reset. I had the same problem, on mine I held down the reset button on the remote while manually turning off the tv. The TV went off, then came back on. It's working perfectly again.
Was this helpful?
Yes
No
Solution #2
posted on Oct 07, 2009
Not Rated)
zapdbf
Rank: Guru  Sony Expert
Rating: 96%, 89 votes
Vertical colored bars are a communication problem between the light engine and the q box, You could have a bad lvds cable which is what they communicate through. Unfortunately there are specific diagnostic steps a tech will have to do to determine which one is defective. and the results of the testing are not always absolute. I have had to diagnose this issue before and it requires bringing up video patterns that are located in the light engine micro and the q box micro to help in isolation.
I cannot give you a good estimate on repair because the q box and light engine are extremely expensive. If you are lucky and it is the lvds cable it would not be much to repair around $150 or so.
Was this helpful?
Yes
No
Popular Solutions for Sony KDF-E55A20 55 in. LCD
Questions and Unsolved Problems for Sony KDF-E55A20 55 in. LCD
Do you recommend Sony KDF-E55A20 55 in. LCD Television?
Answer
Answer
this morning my sony kdfe55a20 was working fine.. sudden loud popping sound and picture/sound gone..... (More)
Answer
tv works fine for about two minutes and then picture and audio disappear. power indicator on the tv... (More)
Answer
my tv works fine and then the picture goes black and sound goes out then the picture comes back... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
