Question about Toshiba Televison & Video
Flyback transformer I was told I need to replace the flyback transformer. Is oem the only way to go? How much is reasonable to pay? Should I just invest the money in a new TV?
    Scholar:
  • 57 Answers
You can always get a second opinion from another tech and a bid before you decide. I repaired TVs for over 30 years and replacing a fly back is not a hard job. But you should consider the age of your unit as other parts also ware out, such as the projection tubes Red, Green, and Blue, These have a limited life span and are costly to replace. If your screen starts to get a color becoming predominate while viewing a black and white image or if the picture starts getting a silvery Hugh on a bright scene that could also be a aging problem. TV only last so long then need repair or replacing.
Posted on Oct 07, 2009
    Scholar:
  • 102 Answers
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Picture on Samsung TXL2791F gets smaller after a few minuets
The horizontal output transistor that drives the flyback transformer overheats now. There might be other reasons too for this fault. If the flyback transformer has any internal winding short, this transistor will overheat.
Just replace the horizontal output transistor. Check its heat. If the newly replaced transistor too overheats, replace the flyback transformer.
May 24, 2012 | Samsung TXL2791F 27" TV
Tv dont come on but have a clicking noise, the led blinks with a click
I have a Samsung 32" that did the same thing a few weeks ago and I am still trying to fix it. The problem is the Main Flyback Transformer is blow with an open circuit in the Primary Winding that means you'll get no Picture. I also found the Power Transistor that feeds this Flyback Transformer was also shorted between terminals Collector Base Emitter(CBE). I bought a replacement Flyback but didn't work so now I need to get the Original part & it's not easy to find. Always use Original Components NOT replacements. Simply put if you're not technical I suggest take the TV to your nearest repair agent but be prepaired to pay for it. Cost of Flyback around US$50 & $10 for Transistor & if you find an honest repairman it should cost around $150 to repair otherwise it's not worth it. Good luck
May 30, 2010 | RCA 32F531T 32" TV
Kp-fs57 blue screen then turns off
Could be one of three things the yokes, the flyback transformer or the picture tubes, all will be a costly repair. If it was mine I would invest the money in a new one.
Sep 09, 2009 | Sony KP-51HW40 51" Rear Projection...
I was told tthat the flyback is bad on my toshiba tv model #CF36G40 can i replace the flyback myself? Is there any adjustments that need to be made after replacement?
Stay the hell away from a flyback. It will knock you clear across the room! The only thing I look for in a tv is an internal fuse, and then I look very carefully. If I don't find a fuse, I toss it.
Apr 29, 2009 | Toshiba Televison & Video
Flyback transformer?
Its either the flyback or a regulator. But i would need the model number of your set in order to know for sure. Please reply to this same post with your model number.
Aug 02, 2008 | Televison & Video
Phillips 60pp9202 high voltage transformer
You can get the HV Transformer at the following link for 132.00 which includes free shipping and free step by step instructions by online instant messaging so you can easily replace the part yourself. Very easy repair. The HV generator is listed under the flyback section yours is Phillips 32942 Flyback ( HV Transformer)
Heres the link.
http://servicemanuals.vstore.ca/
Aug 01, 2008 | Philips 60PP9202 60" Rear Projection...
RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
May 29, 2008 | RCA F32650 32" TV
Flyback transformer BSC 70Y
You will find the flyback on this site.
May 02, 2008 | Apex Digital PF3230 32" TV
Pincushion problem
My thoughts would be, was it a Sony OEM transformer or a generic type? If the latter, that is probably a likely suspect. Another thing would be misplaced wires or switches that could have been accidently moved while replacing the transformer. I have had some of these sets that had no high voltage, and all it turned out to be was a broken solder connection on one of the pins going to the flyback transformer. Usually, if the flyback is bad, the Horizontal output transistor would be also defective. It's also possible that in the process of removing the old flyback (fun job wasn't it?) you may have cracked one or more of the circuit traces in that area of the PC board.
Jan 01, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Toshiba 35A44 - Dark picture on all channels and DVD's
for this brightness problem actually came out from flyback transformer...so, before you spend and waste your money, try to adjust at back of your tv first. But if you aren't an expert, better ask technician to do because that transformer supply a very high voltage....there's two adjustment point at flyback transformer, one point for focus and the other one for brightness! try first...
Nov 06, 2006 | Toshiba 35A44 35" TV
Televison & Video Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
