Question about Maytag Dryers
My maytag dryer makes an obscene rumbling noise every 10 seconds. It's still running and the heat works, but it sounds like it is about to shake itself apart.
  • Maytag Master
  • 7,482 Answers
I have not heard it call obscene but your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Posted on Oct 08, 2009
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer making a rumbling sound when running
It is normal for the dryer to make sound due to the high velocity of air moving through the dryer drum and exhaust system.
A clicking noise may be the timer advancing.
Check the load for objects such as coins, nails, etc. Remove promptly from dryer.
It is normal to hear the dryer gas valve or heating element cycle on and off during the drying cycle.
The dryer should be level and installed on a solid floor.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Maytag MED9600S Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
MayTag Neptune MDE6800AYW dryer drum making rumbling knocking noise
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Jul 09, 2009 | Maytag Neptune MDE6800 Electric Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Dryer makes rumbling sound when starting
If you remove the front cover and access the blower fan and see if it is still tight on the shaft. if it isn't it makes a rumble sound when started due to vibrating and after a while it makes more noise as it goes. Now I removed the fan and placed a shim in the flat area and matched the flat area of the shaft and replace it back on the shaft and it should solve it.
Mar 21, 2009 | Maytag MDE2600 Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
