Question about Kenmore Microwave Ovens
The letter d comes up next to the clock and now it wont heat anything up
  • Kenmore Master
  • 9,047 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Oct 11, 2009
It comes on but wont heat, there is a clock icon on it that ive not seen before, and its not in the manuel
sorry there are too many MAKes to begin a guess try calling a repair service local to you
Sep 27, 2016 | In Microwave Ovens
M625eg microwave not heating light comes on and clock working held within a built in unit would like to get it repaired
There are three common issues, magnetron "heats food" high voltage diode "sometimes cracks and developes a short" next is the high voltage capacitor "odd time will short" I recommend a professional lethal voltages present.
Mar 09, 2012 | Microwave Ovens
We tried to use or keypad lastnigt- nothing on it will do anything. Light inseide is on and is telling us to press clock.
Your description sounds like power failure, after failure on some machines you MUST set clock next. Before you do anything, unplug unit for longer than 45 seconds, then plug in, set clock and go from there.
Sep 26, 2010 | Microwave Ovens
I moved my microwave with it plugged up, and it comes on, clock and everything works but it's not heating anything
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Aug 16, 2010 | GE Microwave Ovens
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Have ge sensor microwave model Je1660w
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
62y
Apr 22, 2010 | GE JE1540 Microwave Oven
Microwave wont heat
look at the $2.00 door safety interlock switch(s) before you replace the very expensive (and hard and dangerous) magnetron.
Dec 23, 2009 | Kenmore 63252 Microwave Oven
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
