Question about Whirlpool Ovens
Whirlpool double oven Model#: RDB305PDB12 Ran self cleaning oven and it completed the cycle and unlocked. Lost power - checked breakers and they are ok. The oven now has no power to it. Any ideas? Thanks, Dan
There is a tco (thermal cut off) part under the control pannel.
the local electronics store had them but not the right temp. choices for me where 1 degree cooler or 7 degrees hotter. the part was under $4. online for the right temp they wanted $15.75 s/h. In my oven it was inline with a black wire. both ends had the knife quick connects and is covered in a thick clear plastic. Be carefull. I dont know how but the ribbon cable for the control pannel broke while i was working on it. :( this $4 part did bring the power back on but because of the cable issue no keys worked.
Posted on Aug 06, 2010
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven door remains locked after self-cleaning
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 27, 2010 | Thermador SC302T Electric Double Oven
I ran the self-cleaning and the door will not open.
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Mar 06, 2010 | Whirlpool Ovens
I need to get my oven unlocked. The cleaning cycle went haywire
or
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven won't heat
Unplug the power cord for thirty minutes, this should reset the oven.
If this still does not work do the following:
Press clean and then cancel. This will reset the appliance.
If the error does not clear , then during the self cleaning cycle, the high temperature has probably damaged the temperature sensor probe, and it must be replaced.
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Self Cleaning Cycle for Oven
I lost the instruction manual for my Whirlpool 30" Electric Built-In Double Oven and want to clean it. Can I get instructions for how to set the cycle for self-cleaning, etc.?
May 10, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RF367LXS Ceramic Glass Range not working
Almost every time I run the SELF CLEAN cycle on my Whirlpool Self Cleaning range, it fails to function after completing the self clean cycle, even though it completes the cycle of cleaning and unlocks the door. What I do to solve the problem, I power off the BREAKER for the range at the main electrical panel in the house and wait 30 seconds, then power on....and the whole system works just fine until the next time I clean it. This has been a problem from the beginning. My theory is that the electronics get heated up and, like a computer, the system stalls out and needs a complete hard reboot. Good luck!
Feb 02, 2008 | Ovens
Oven door locked
First check to see if you activated the "child lock-out". See your manual to deactivate.
You could also try unplugging the unit, or trip the circuit breaker in your home which supplies power to the oven. Wait 5 minutes and turn power back on. This will reset the controls.
Jan 26, 2008 | Whirlpool RBS305PDS Electric Single Oven
Open Questions:
Ovens Logo
167 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
