Question about X2Gen MW22U Monitor
Power lamp just blinks after power outage on my street
    Problem Solver:
  • 5 Answers
The post in following link fixed the same issue I was having with one of my 22 in X2Gen monitors. http://www.fixya.com/support/t2356502-x2gen_capacitor_location
Posted on Oct 22, 2009
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Nov 26, 2007 | NorStar Meridian M7310 Phone
I recently was watching my projector and we had an power outage I now dont see the light but the fan is on and power button blinks when I turn it on and off what could it be
I am afraid that your bulb died. That is highly recommended to use projectors with a UPS system because their lamps are so fragile...
Hope that someone will have better news for you...
May 08, 2011 | Audio Players & Recorders
Power standby is flashing after power outage. the light is flashing 6 times. what should i look for?
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Mar 28, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Monitor blinking after power outage
Check the power supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 27, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blinking light won't stop. It does not reset. Please help. Thanks
A quick fix that might get that out the way. Reset the lamp timer. Other wise you might be looking at a bad ballast. hard to tell w/ out knowing which indicator light is on.
Apr 21, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking Gren Light on 52 Inch DLP
It most likely burned out the Lamp. DLP TV's need time to cool the Lamp after power is turned off.The fan will run for a few minutes after a normal power off condition from the front control button or the remote.When you lost power, the lamp was still hot and was unable to cool down.You can replace the Lamp yourself.Go to www.dlplamps.com
Jul 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
Blinking yellow light ,no picture or sound.
You have done all you can do. If you had a power outage, when the power came back on a it surged and probably caused a Power Supply problem or something in the micro controller to fail. Either way it 's not good. I would call Toshiba and let them guide you to a Service Facility that can check it out. Depending on your Homeowners Insurance, repairs could be coverd or unit be replaced depending on cost to repair.
Sorry I am not able to help further,
skyassoc
Jun 22, 2009 | Toshiba 65HM167 65" Projection Television
Power button blinks after power outage.
i have the exact same problem, can anyone help?
Aug 09, 2008 | HP Pavilion s7310n (EN996AA) PC Desktop
X2Gen MW22U Monitor Logo
123 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
