Question about Alert Welding Tools
1 sq ft of carbon steel 1'' thick weighs what
    Problem Solver:
  • 5 Answers
40.833333 LB
Posted on Oct 10, 2009
4 ft x 4 ft x 5 inches = square foot?
when I went to school a board foot a board 1 foot wide and 1 foot long 1 inch thick, a 1X6 2 foot long a 1X4 3 foot long etc. a 4X4X3 inches would be considered a board foot but with new math and metric system, I'll leave the exact formula to the calculators and smart phones (I don't own one) 20 square feet would be my answer,
Apr 16, 2017 | Office Equipment & Supplies
How many square feet are in .014 of an acre. I'm buying it for 6.00 a sq ft.
From what I could figure that would be around 609.84 square feet.
Jan 19, 2017 | Garden
Need torque specs for primary and secondary clutch bolts
Hi Josh, most of the fasteners on motorcycles are made of medium carbon heat treated steel SAE grade 5 or better.
1/4"-10 ft-lbs.
5/16"-20 ft-lbs.
3/8"-35 ft-lbs.
7/16"-55 ft-lbs.
1/2"--75 ft-lbs.
Good luck and have nice a day.
Nov 17, 2015 | Motorcycles
Rear axle tourque specs
Hi Anonymous, most of the fasteners on motorcycles are made of medium carbon heat treated steel SAE grade 5 or better.
1/4"-10 ft-lbs.
5/16"-20 ft-lbs.
3/8"-35 ft-lbs.
7/16"-55 ft-lbs.
1/2"--75 ft-lbs.
Nov 02, 2015 | Motorcycles
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
How do i convert 60 tons of ashpalt to square yards
AC is approx. 145 lbs per cubic ft.
there are 27 cubic ft in 1 cubic yard
60 tons x 2000 = 120000 divided by 145 = 827.58 cubic ft divided by 27 = 30.65 cubic yards
square yards would depend on thickness of AC.
you can take thickness x sq ft to get cubic ft
in concrete 1 cubic yard =
4 inch thickness = 81 sq ft or 9 sq yrds
6 inch thickness = 54 sq ft or 6 sq yards
Feb 16, 2015 | Heating & Cooling
1 gallon of any liquid, poured out at 1 mil wet film thickness, will cover approximately how many square feet?
One gallon when applied to a horizontal wall will cover 820 sq. ft. above 87 degrees F. OAT, standard humidity, MSL. thirsty , smooth surface and a way to measure and maintain a 1 mil thickness, in-doors and oil based paint, will skin over as it dries. latex will measure to 1200 sq. ft. @95* F.
Oct 04, 2014 | Tools & Hardware - Others
Republic EZ broadcast spreader...what number to use when lining up the mark to calibrate the spreader...lost the instruction book
Hello, to solve your question about what number to use to calibrate your broadcast spreader, please use the step-by-step instructions below:
1. If you don't already know the square footage of your lawn, please walk off or measure, multiplying the length by width. For example, my lawn is 100 ft wide by 100 ft long; this equals 10,000 sq. ft.
2. Use this figure (30,000 sq ft) to determine how much fertilizer, insecticide, fungicide,apply etc., to purchase and apply.
3. To calibrate the spreader for applying your product at the correct rate, first weigh and hold out an amount of product to cover a pre-determined test area; for example, enough for a 200 sq ft space.
4. Because most lawn fertilizers are packaged to cover areas in 1000 sq ft increments, it's easy to figure how many 1,000 sq ft applications you need for your lawn.
5. Set your spreader to 3 and measure 1/5 of the recommended application on your product, to cover a 200 sq ft area.
6. Use your spreader to cover this 200 sq ft area.
7. If there is product remaining in the hopper after walking this 200 sq ft area, increase the setting number and move to another test area, repeat steps 5 and 6.
8. If there wasn't enough product to cover the test area, back the number down, move to another test area, and repeat steps 5 and 6, until you finish with product and lawn test area at the same time.
9. Remember to never leave product in your hopper because many chemicals are corrosive and can destroy the moving parts, making the spreader inoperable.
I hope this helps!
Apr 02, 2011 | Garden
I need spreader setting to do 2.3 pounds per 1000 sq ft
If the product you are planning on applying has a spreader setting for a Scotts SpeedyGreen, or specifically for the SpeedyGreen 3000; you can that recommendation in your Edgeguard Deluxe Spreader. If they do not have a suggested spreader setting for the SpeedyGreen, or SpeedyGreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
We do have a general rule, called the 50 by 20 rule which will allow you to use any product in any spreader, but there is some work that will need to be done.
* Weigh out and Place enough material in the hopper to cover 1,000 sq. ft. (In your case 2.3 pounds)
* Place the spreader setting on a low setting (Usually one-fourth of the spreader setting range or less. In your case i would suggest about 2.75 or 3)
* Spread the material over a 50 x 20 ft. area (This is 1,000 sq. ft.).
* If material is left over, you will need to increase the setting accordingly
* If they you up short, you will need to decrease the setting.
Feb 17, 2011 | Scotts Company Scotts Lawns Edgeguard...
Welding Tools Logo
Top Alert Welding Tools Experts
Bill Boyd
Are you an Alert Welding Tool Expert? Answer questions, earn points and help others
