Question about Seagate (ST9402113A) 40 GB ATA-100 Hard Drive
Failed segate drive need replacement solution
I have a segate 40 GB ATA-100 notebook harddrive that is failing.
I need to replace the drive with a compatable drive for the notebook.
Any suggestions?
Will a ATA-300 drive work?
  • 31 Answers
Yes the ATA-300 is compatible with notebook computers.
I use Hitachi HTS7210 80GB.
Posted on Oct 07, 2009
No format , no partition, this drive is security freeze locked
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
May 10, 2011 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
Replacement hdd for a Toshiba MK4026GAX (ATA)
Any brand-new ATA hard-drive (you probably won't find any new hard-drive smaller than 80GB) will be compatible. Pay a few extra dollars for a 7200 RPM drive (rather than 4200 or 5400 RPM).
Nov 14, 2009 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
Seagate Baracuda 7200.7 in a RAID0 array has failed. On Drive diagnostics Drive test get error message "Drive Failed! Return Code 7". What is the drive error?
Hello mmincalgary:
This drive error code 7 means the controller board that controls the drive has failed, the board is located on the harddrive itself, Replacing this drive will solve your problem, unfortunely Segate has had many issues with this drive especially the SATA ver .7, 160GB versions..
Sep 26, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Replacing failed hard drive
it depend upon ur bios version
u can have hard 40 to 80 Gb
Mar 22, 2009 | Dell Latitude D600 Notebook
Seagate Hard Drive 40 GB ST9402113A
Hard Drive: Seagate has a downloadable diagnostic program which can help determine the defect. My experience is that once these things fail, it is best to replace. There used to be repair centers where you could send hard drives, but with the low cost of new replacements, it isn't economically feasible. Data recovery is expensive, should you desire that. Google for repair/recovery centers if you want to check out those routes.
Keyboard: It looks like the built-in keyboard is defective. Repair of the original is doubtful. Unless the laptop is old, you might be able to obtain a replacement from the manufacturer. I have replaced a few laptop keyboards in Gateway machines here at the college where I'm employed.
Mar 04, 2009 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
Toshiba Motherboard and Harddrive
No you can't replace the ata m/board but you can upgrade your hdd's up to 160gb in ATA
Dec 08, 2008 | Computers & Internet
What to do with unreadable but recognised hard disk segate 400GB
After data is recovered, it should be moved to another drive to keep safe. The drive that was recovered has to be reformatted and checked for errors before storing more data.
Nov 28, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate (ST9402113A) 40 GB ATA-100 Hard Drive Logo
122 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
