Question about Refrigerators
Model #MSD2735GRW--leaking water inside the freezer and freezing 10 inches of ice on the bottom where the basket rests. cannot see any visible water leaking. HELP
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 07, 2009
Thank you SO MUCH for this. I had the exact same issue. I have all the Ice removed now. Took the back panels off and cleared ice from the coils too. I just dryed everything and seeing if the drain tube is clear now.
Posted on Dec 01, 2012
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
Hi, have have 21' Bottom Freezer refrigerator, model 69142992. My bottom freezer is getting a sheet of ice on the bottom, where the basket becomes frozen in place. The the freezer leaks water onto the...
hi dear you have to unplug ur ridge and then open the freezer door remove the food try to defrost the ice by a hair dryer then remove the basket boil some water and pour it on the white metal back inside the freezer tell you feel the water goes inside ,your problem is drain blockage ,or stop the fridge for 24hours and it will work normally
Sep 11, 2010 | Kenmore Refrigerators
Freezer icing up
Experienced this problem with Evaporator coil icing up (coil is located inside back wall of the freezer compartment; the ice/frost was visibly blocking the series of louvers or slots along the bottom of the freezer back wall. I think the power outage caused partial melting of an already somewhat iced coil, but when the power was restored the water on the coil just froze solid. When these slots become obstructed the Refrigerator will not cool to its proper 36-40 deg.F temperature and the compressor motor runs frequently and the noise level is louder than usual. SOLUTION: fastest and safest way to Defrost this iced up coil is: (1) turn off 120V power / unplug refrigerator from the outlet; (2) remove all food to another refrigerator / freezer and take out ice cube tray & flip icemaker bail wire to its up (off) position - but leave top freezer basket in-place; (3) remove Bottom freezer basket (which should lift up and out; (4) move refrigerator away from wall - and carefully unscrew and remove white-painted, rectangular metal panel at bottom in the back....... you will see a white plastic water tray below a small fan with black plastic blades...... have a 3x5 cellulose sponge and bucket handy...... (5) open freezer door all the way and set a 21-inch box fan on the floor in the opening or area where the Bottom freezer basket was removed... put a single towel on floor under the box fan if there is significant frost on the bottom of the freezer compartment (there should not normally be any); (5) turn the fan to "Medium" speed with air flow pointing toward the freezer... you will be amazed at how much faster this works than pans of hot water or hair dryers (the latter is potentially damaging and dangerous); (6) with a flashlight you should soon see the water drip-drip-dripping from a spot at the center and bottom of the Evaporator coil - where it goes down a white tube and into the white plastic pan beneath the small fan you saw in Step #4; after awhile (maybe 20 minutes) check the white plastic tray in the back - which will be full of water (sponge it out)... continue defrosting with the 21-inch box fan... check the plastic tray again - and sponge out the excess water. A completely iced-up coil will probably fill the plastic tray three times. Eventually the water will stop dripping - which means the Evaporator coil is completely defrosted. There may be some water that gets onto the floor under the left side of the refrigerator which you will have to wipe up. Reattach the metal panel and reinstall the Bottom freezer basket and ice tray. This process takes long enough that you can clean the inside of the refrigerator while you're at it.
Jul 09, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Freezer model EV171NYMS04 we have ice build up on
There is a drain the back of the freezer that is frozen. Your trickle of water comes from the ice that melts off of the refrigeration coils during the defrost cycle. You need to turn off the freezer, then remove the rear cover from the back wall to expose the coils. With a hair dryer, melt all of the ice. You will find a drain under the coils. Melts all of the ice in this drain so water can get out of the freezer. When this drain is clear, you can put everything back together, and your freezer should work normally.
Mar 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Water collecting and freezing in bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coil. Remove the ice and flush the drain hole with hot water to make sure it is free. You can try running a soft wire through the drain also.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire FRS26R4A Side by Side...
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
Roper Refrigerator, top freezer leaking water into refrigerator
This is usually caused by a plugged freezer drain. The back wall (or floor) of the freezer may come out to access the drain. Clear out anything visible and run a stiff wire thru it. Test with a cup of water. Hope this helps!
Dec 31, 2008 | Refrigerators
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
