Question about Intel Motherboard
Msi motherboard p4m900m2
I just install a new mother board and cpu. I am using my old hard drive with xp operating system and now it would not boot up. It comes as far as the safe mode with the other modes and when you try one it starts and come back to the same place. Please help me solve this problem
  • shaystudd Dec 24, 2007
    how do you do a clean install without lossing any data
  • shaystudd Dec 26, 2007
    Yes I really understand your solution. You have been very helpful.Thanks to you I am up and running again. Shay.
  • 78 Answers
Are you using the exact Motherboard that you replaced? If not you will need to do a clean install of XP to make this work. it is trying to load from the old motherboard. a clean install will sove this problem
Posted on Dec 24, 2007
  • Paul
    Paul Dec 26, 2007
    shaystudd,
    If you need to backup your data take the harddrive to another computer, the easiest way to is to put the harrdive on it's on cable (remove from the CDROM drive and attach your harddrive to it) this way you won't need to change the master setting on the harddrive. boot the computer up and you should see the C: drive and also an D: or maybe E: drive. I normal create a Backup folder on the desk top, then open the D: or E: drive which will be your harddrive. go to D:/Documents and Settings\YOUR PROFILE... when you open what every your profile is you will see MyDocuments, Desktop, and Favorites. I usually copy these 3 folders at least to the desktop folder you created. you may have items in another location to save also let me know if you need any more help with that. after you do the clean install you can slave the hardrive back to the other harddrive or if you have a jumpdrive or CD burner you can copy the data to that. I would recommend keeping a copy of these files all the time anyway just incase your harddrive fails later down the road. Good luck
    Guru:
  • 1,894 Answers
After fixing a new mother board u must reinstall your operating system. the driver settings change for each mother board
  • 5 more comments
  • dewan nafees ahmed Dec 24, 2007
    the old hard drive with XP in it will have the operating system settings for the old mother board.
    so once you reinstall your operating system the settings for XP will set according to your new mother board. hope you know how to install your operating system,
    ya if the new mother board is same as old one there is no need to install the operating system again. can you be more specific with the problem.
    this installation can be done by formating the drive containing the operating system fully and putting the operating system again freshly. for doing this you need a operating system disk.
    if you dont need informations on another partition of your hard disk you can install the operating system in that drive..
    else you wil have to connect the hard disk to another system as a slave and back up your data. then connect it to your system and install the operating system
    if you want the data to be protected only two ways are there as i said. even there are some complex ways. but you wont be able to do it easily. two easy ways was what i told in my last comment.
    1>> install the OS in partition in which you wish to loose its data.
    2>> connect it as slave in another PC and back up your data in that PC or in a CD ROm.
    did you understand my solution or not?
    why no comments form you?
  • dewan nafees ahmed Dec 27, 2007
    what is happening here? i gave the solution first. the the another solution, which was same as mine given later was accpeted as best one? tis s too much guys.....atleast u could have left me a rating....
I cannot start my computer after replacing motherboard and CPU. How do i install Windows onto the motherboard and how do I install eJiffy?
You forgot to sysprep the OS before removing the old board.
Put the drive back on the old board and CPU and let it boot up.
now sysprep the drive THEN re-install the new board and CPU
To sysprep the drive, do the following:
>There is a SYSPREP tool on the XP CD.
>You may need to extract files from the Windows XP CD, files are located at CD:\SUPPORT\TOOLS\ in a cab file called DEPLOY.CAB. The files are Sysprep.exe and Setupcl.exe.
>With the old motherboard still intact:
>You run sysprep and "RESEAL" Windows XP.
>Then you put the new board in, and it re-activates Windows XP and populates the device manager list.
>You do need to re-activate with the same key-code, and if you exhaust that number of activations, it will prompt you to call Microsoft and you get a new release key at no cost from them over the phone.
The basic problem here is that when windows goes to initialize the old hard disk controller, it loses the hard disk because the controller isn't the same.
It may also be crashing as it tries to initialize other hardware, but it needs that IDE or SATA (or SCSI) controller online even to get into safe mode!!
Good luck - sysprep works about 90% of the time, but if you run into problems, it can be a real bugger to untangle!
Feb 27, 2011 | Computers & Internet
I have a MSI K9N6PGM2-V mother board with AMD CPU. It has problem to read hard drive or DVD writer during bootup. The BIOS of mother board can see the two drives. However, it cannot read data from any...
Hello, Please try and insert the DATA cable properly from the motherboard to the hard disk as well as DVD writer,and try and interchange the power cable to this devices, or change the power pack and see if the problem continues.It might be that the power to this devices are not enough. If this fails, then try installing a different operating system. Cheers
Dec 08, 2010 | MSI K9N6PGM2-V Motherboard & AMD Athlon 64...
XP not recognizing 5th SATA drive in new motherboard
Since you are a experienced PC user, I will cut down to the chase as I might have a idea what your problem might be. I tried to find more into on your issue but couldn't source anthing of importance:
It might be that your last SATA port that you have connected your hard drive is different from all the remaining 5 - Meaning it is set up differently BY DEFAULT in the BIOS. FOr example it might be set up to be on a certain "RAID" setting or mode that might prevent it from being seen within Windows XP.
What I am trying to get at is that maybe that last drive "mirrors" another drive by default.
Please try also to download the latest BIOS for you mainboard, and make sure all hard drives in the BIOS have the same setting on them individually. Spefically, check your RAID and AHCI settings, boot up lineup and other settings that might influence this.
Also check if your new hard drive isn't faulty, since it picks up in BIOS but not in device manager - The drive might have a plate fault or a read/write head issue. This might explain why it is visible in both the BIOS AND the device manager under "Hardware devices" but not in the "Disk Manager/Management".
As you know how to format and partition a drive, i do not need to query if the drive as been initialized, since you already have set up the other 4 hard drives without a problem.
May 24, 2010 | Microsoft Windows XP Professional
BIOS for Windows XP
you don't need to change bios settings to install xp.
just insert xp disk and boot from it.
Mar 28, 2009 | Intel Motherboard
XP to vista and install sata drive
Yes vista will format & install on the new drive. Just make sure if there is an o/s on the old drive that you set up windows vista as a dual boot if you wish to keep using the o/s on the old drive. Hope this helps.
Dec 25, 2008 | MSI K8N Neo-FSR Motherboard
Driver problem
click here to download drivers
http://twotechkys.blogspot.in/2017/09/download-msi-p4m900m2-l-ms-7255-ver20.html
Jun 07, 2008 | Intel Motherboard
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
MoBo Replacement
did you go into the new bios and check to make sure you have the hard drive setting on auto, then check your boot order that the drive is first to boot., if that doesnt work create a floppy boot disk (google it) and see if you see the hard drive when you do that.
Feb 15, 2008 | Computers & Internet
Boot up problem
Did you go into your bios and reset with factory settings. Also did you try to boot up with the windows xp installation disk. Try that and let me know what happens. Are you sure the hard drive is ok too. let me know if you get it going if not get back here. I'll be in and out all day so when I get your message back I will get to you asap.
Thanks hope that helps some. You get into your bios by pressing the delete Key or F2 key when your are starting up and your computers logo is on continue pressing until your bios screen comes on. Read your instructions and follow how to reset bios to factory settings... anymore ?s just ask
Dec 24, 2007 | Intel Motherboard
Intel Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
