Question about Apple iPod touch
How do you unlock an ipod touch if its locked
  • 496 Answers
1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
2. Open iTunes and sync the iPod as normal.
3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it
Posted on Oct 07, 2009
SOURCE: i forgot my unlock code for my ipod touch
my i pod is locked i forgot the code pls help me
Posted on Sep 15, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: cant open ipod touch its locked
okay for all those who cant remember their password code pls follow this http://www.youtube.com/watch?v=cenCotyWRbM
pls follow the instructions given
if this help pass it on and feel free to rate the help given
unlocking ..............................................
Posted on Apr 11, 2009
SOURCE: my ipod toch got locked and i cant unlock it how
ok to unlock it put it in recovery mode then just restore it
Posted on Jun 06, 2009
dalegough
  • 12 Answers
SOURCE: cant slide to Unlock
try holding down the "power" and "home"buton untill you i pod shows the apple logo then try again it will take about 1 too 3 mins to restart
hope this helps
dale gough
Posted on Aug 11, 2009
  • 1099 Answers
SOURCE: ipod touch is locked forgot password cant unlock
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
Posted on May 06, 2010
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
on Jul 21, 2011 | Computers & Internet
Tip
Unlock locked ipod touch without passcode
After reading couple of threads it came to my attention that one of the major issues that a general ipod touch user faces is that some how he or she has locked his/her ipod touch and now can not unlock it. so i am going to give a easy free procedure which will help to unlock the ipod
You can use it for any Version of Ipod touch (1g,2g,3g)
CAUTION:
you will loose all of your data if they arenot backed up.
you will need internet connection for your computer.
let's begin:
#1. Download itunes from here
Install it on your computer and run.
#2.Connect your ipod touch to your pc and press and hold both home(below the display small button) and power( on the top left corner) of the ipod touch untill it turns off and restarts and shows you the connect to itune sign.
#3. your itune will know recognize your ipod touch and it will ask you to restore. Restore it.
wait till it is done restoring. now you have your ipodtouch back on its factory status and unlocked.
hope this will help.
please comment
on Mar 17, 2010 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
How to unlock it
How to Unlock an Apple iTouch
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions
1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen.
2 Slide your finger on the iPod Touch's unlock bar.
3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Jan 07, 2012 | Apple iPod touch
Ipod touch is locked forgot password cant unlock
May 05, 2010 | Apple iPod touch
Ipod 8gb unlock
to un lock ipod touch
Apr 03, 2009 | Apple iPod touch
Cant open ipod touch its locked
Mar 19, 2009 | Apple iPod touch
Apple iPod touch Logo
241 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
