Question about Dishwashers
Dishwasher water is going in then right out not letting machine fill and start cycle.
Make sure the drain hose is at least 20'' above the floor before it goes into a drain pipe. if you have it going directly into the floor it will siphon the water out as soon as it is pumped in
Posted on Dec 24, 2007
I set the dishwasher Siemens SL84A to regular wash cycle . I hear it click like its going to start, warm water fills the bottom up the tub but it never kicks into the wash cycle. Hit the cancel cycle and...
Most likely issue here is that the door is not sealing properly or the sensor on the door is not working, so it can fill up much as your washing machine does but just as the washer won't spin without the door closed neither will the dish washer. An easy way to check this is to let it fill and then lean or push against the door some and see if it starts, if so then the issue is the isn't sealing properly.
Dec 04, 2013 | Siemens 24 in. SL84A305UC Built-in...
Kenmore dishwasher will not fill with water model no 630.1609406. It will run a full cycle but not fill. Water was temp shut off to replace kitchen sink and now dishwasher won't fill with water. No fill...
First, are you sure that the machine is not filling?
I go on calls all the time for this problem and it turns out than the machine fills but the wash motor does not run.This leaves soap in the bottom of the DW so it looks like it did not fill with water. This is a common problem in dishwashers that have not been run for a few months, and is quite common after a remodel. If it IS getting water, the motor is probably stuck. If it is Not getting water the first step is to locate the "over fill" float inside the dishwasher. This will be a round sort of mushroom looking thing on the floor of the machine near the door on the right or left. Make sure it moves freely up and down. It will only move about 1/4 inch but If it is stuck up, the machine will not fill. If float is O.K. then check the water source. Turn of water to DW. Remove the kickplate under DW door and disconnect the waterline from fill valve (should be on front left side of unit). Run waterline into bucket then turn on the water. If you don't get water call your plumber. If you get water then you need to check the fill valve. Connect a volt meter to the 2 wires on the fill valve. Start DW. First the diswasher should start draining, then it will start filling. At this point (a few minutes into the cycle) you should see 120v AC at the fill valve. If you do see 120v Ac, replace the valve. If you don't , then turn off the machine and check the float switch. This is located under the DW right under the mushroom thingy. The switch should have continuity when the DW is empty. If there is no continuity then replace the switch.
Mar 29, 2010 | Dishwashers
Water will not flow into dishwasher . will complete cycle but no water in dishwasher.
start with the water going into machine chek under the sink fill hose and check with a meter the water valve its normally one or the other.let me know with a 4 thumbs up post
Feb 27, 2010 | Dishwashers
Dishwasher leaks at start
Is the washer not "over filling" due to the water fill vacume pipe and micro switch that shuts off the water once the correct level blocked or restricted due to fatty residue? This could also be one of the washer pipes clogged up and increasing the pressure in the fill tank.
Jan 20, 2010 | Dishwashers
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Hobart glasswasher: it fills but then nothing
Did you solve your problem?It takes 8 minutes to fill.I'm a hobart tech,let me know.
Apr 11, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
As soon as you turn on power it starts to fill
It will look to the wash tank float to determine the water level and temperature. If the machine is empty, it will fill first. before letting a cycle start.
Apr 05, 2009 | Hobart LT1-1 Dishwasher
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Dishwashers Logo
111 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
