Question about Philips 43PP9202 43" Rear Projection Television
Philips 43pp92 blue will not converge - Philips 43PP9202 43" Rear Projection Television
    Top Expert:
  • Philips Master
  • 14,553 Answers
You have a $ decision---this model uses two STK-392-120 convergence IC's--if it will not adjust one is bad.
Both need to be replaced--you can buy a pair on Ebay for less than 14 dollars plus shipping. Sometimes there will be a bad resistor near on of the chips that also needs to be replaced--this is a very common problem in rear projection TV sets--I have repaired hundreds of sets with this problem.
If you cannot do the repair yourself shop around your area--most shops charge about 300 for a repair like this on your set-I do lots of them here for 200 total.
If the $ cost does not make sense--it is time to buy a new TV--but remember this kind of set has a lot less problems than LCD or Plasma TV sets.....
If you have any questions or need more information let me know--I am here to help people.
Regards, SD TECH
Posted on Oct 07, 2009
Testimonial: "Very helpful info for an exact described problem. Thanks & God bless you!"
4 Suggested Answers
techman
  • 3130 Answers
SOURCE: Philips 43pp92 blue will not converge
Those are called circuit protectors or fuses.
Posted on Nov 27, 2007
albertv29
  • 87 Answers
SOURCE: Phillips 43PP92 0217 red blue converge
The ICs are STK392-110
Posted on Jan 12, 2009
Ecollier2012
  • 3459 Answers
SOURCE: 43pp92 philips 43" HDTV blue convergence went out of whack
Get a convergence kit from www.TvRepairKits.com
Posted on Jun 06, 2010
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Remote will not adjust red convergence/multi-point horizontally
check resistors around convergence i.c.(red) philips may use 2 resistors in parallell. should be about 1.8 ohms. assuming you already changed the i.c.
Jan 17, 2009 | Philips 55PP9352 55" Projection Television
I have a Philips DPTV305 43pp92 0217
Set the tv at the road to be picked up tomorrow.
Jan 09, 2009 | Philips 60P8341 60" Rear Projection...
here is the sulution to ure coror problem take the back of the tv off turn on the tv and look directly into the bulbs blue red and green most likely you will see that the bulbs look cloudy the liquid in the bulbs after time begains to grow a fungus in them u need to get some crestail crear projector bulb fluid take the bulb assembly out of the the tv there r 3 of then take a socket wrench and un screw the bulbs take after draning the curent fluid out therr is a drain plug on the bottom then dissasimble the bulb and clean the projector magnifine lens with windex and a lint free paper towls clean the gasket as well onces you get the filmy fungus out of the bulb make sure u do not touch the inside and get it dirty again put the bulb back together then fill it up with the new fluid make sure to tap out the bubbles then put the plug back on it a reinstall the bulb ONLY DO ONE BULB AT A TIME SO U MIX THEM UP reinstall the wireing to the board then do the next one once ur done u will need to fight with the alinment ajustment inside the tv and also in the programing also might have to set ur colar to if ur scared to do this a tv repair man charges about 350 to 450 $$$ to do trust me u can do it your self just be carfull dont get water on the motherboard
Jan 02, 2009 | Philips 60P8341 60" Rear Projection...
Philips nr.43pp7445/69
I don't understand you language but I think you need both convergence amplifier IC's replaced. I hope this helps.
Aug 17, 2008 | Philips 60P8341 60" Rear Projection...
Phillips 43pp92 0217
Sorry to bother you again but I did some research and the chip numbers are STK 392-120 but using STK 392-180 is recommended replacement. If the picture is bowed or skewed any at all then the chips are needed replace both and check if any 6.8 ohm resistors are burned or open. Resistors Can be measured out of circuit with a digital volt-ohm meter. Have you tried the consumer menu and located the convergence adjustments? If it only need touch up you should go there. And the numbers I gave you 062597 must be followed with pressing the status button on the original remote. this goes into the service menu and adjustment to convergence can be made there also if touch up is needed or after you replace the chips Hope this helps
Dec 30, 2007 | Televison & Video
Question on Phillips 43pp92 0217
May not be the chips. Try this: go to remote and press 062597 then status to get into the service mode. The menu after that is easy to follow. Hope this helps
Dec 30, 2007 | Philips 43PP9202 43" Rear Projection...
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
189 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
