Question about Jenn-Air JGR8850 Gas Kitchen Range
Bake only heats to 75 - Jenn-Air JGR8850 Gas Kitchen Range
    President:
  • 1,304 Answers
You have a bad ignitor on the bake side
take out the racks
take out the bottom pan
you should see the ignitor
tun on the range and watch the ignitor
if its only orange and notr glowing white
it wont open your gas vaslve
asnd need to be replaced
Posted on Oct 07, 2009
I have a Whirlpool Self Clean oven Model number:RBS305PDS17. I used the self clean feature and now my oven will not heat up. All the digital controls work such as preheat and temperature, however there is...
Error code E2F3 indicates oven overheating, i.e. sensor is not cutting off heat. Replace the sensor, about $75 online. If you have done this more than twice, or if oven is acting strangely (for instance, broiler comes on during "bake" preheat), replace control board OEM part #8302994, about $170.
Aug 16, 2010 | Whirlpool Ovens
I have not so new Kenmore 790 gas range oven. The gas range and brioler work but the oven won't heat up. Suggestions?
I have the same oven and the same thing happened to me. I had to change out the heating element to Ignite the lower baking part. Trying to change it out is another story. I used metal snips to "open" the rear part to change it out. I was not ready to take apart the whole oven. The Part cost about 75$ from a part store, and the connections are easy. Hope this helped.
Aug 12, 2010 | Kenmore Ovens
Have spectra extra large self clleaning oven never had trouble oven does not work i was baking and it worked fine. Then when I went to bake later and turn the oven on it clicked but never got hot. Yhe...
Hello - Most troubles with ranges occur during the "self-clean" cycle. The problem- no lower burner- could be a bad ignitor. Part is 40-75$ Fairly easy to install, or have done for about 75-100$ Let me know if info helps- I have more if you need it - Thanks- ED
Mar 03, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
Kenmore gas (propane) range Model #119.7488810 18-20 years old
you have a bad oven/bake ignitor, althoough you see ther glow, its not "hot" enough to allow gas flow or ignition, very common issue, 2 screws and 2 wires, probably about $75, service company gets min $225..
Oct 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven does not work
most common cause of gas range, oven not heating is a result of a faulty oven ignitor, you would need to verify power(110volts) to ignitor, located under iven floor attached to the bake burner. simple enough job for the homeowner to replace probalby about 50-75 for part
Oct 07, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
I have a frigidaire over model number FGF337AUE that has the same problem many others seem to have which is that the over just won't heat up. It was heating up VERY SLOWLY until today and now it's just...
sounds as if you need a new bake ignitor, def somethin you can do your self, remove the bottom of the oven floor to acess it, its screwed onto the bake burner and either plugged in or 2 wires disconnect right there, bring to a l;ocal wharehouse for the part, $50-$75. installs same way as comes out, remember to unplug unit before servicing wires will be live
Jul 09, 2008 | Frigidaire Kitchen Ranges
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Jenn-Air JGR8850 Gas Kitchen Range Logo
74 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
