Question about Philips 43PP9202 43" Rear Projection Television
43pp92 philips 43" HDTV blue convergence went out of whack
I have Same problem exactly with a 4 year old 43pp92 philips rear projection 43" HDTV, just the other day the convergence went out of whack, I was able to converge the red and green pin cushions, however when i tried to converge blue, it lets me converge the ones closer to the middle, but Top right corner and Bottom left corners, the little crosses will NOT adjust up or down, just left and right.
  • Philips Master
  • 3,459 Answers
Get a convergence kit from www.TvRepairKits.com
Posted on Jun 06, 2010
Philips 43pp92 blue will not converge
STK392-120 is convergence correction amplifier.. the problem is the convergence circuit... try to check the small Valuie electrolytic capacitors or High value resistors! maybe the said parts is in change Value... used a ohmmeter tester to find the chenge value parts!.
Nov 05, 2007 | Philips 43PP9202 43" Rear Projection...
You have a $ decision---this model uses two STK-392-120 convergence IC's--if it will not adjust one is bad.
Both need to be replaced--you can buy a pair on Ebay for less than 14 dollars plus shipping. Sometimes there will be a bad resistor near on of the chips that also needs to be replaced--this is a very common problem in rear projection TV sets--I have repaired hundreds of sets with this problem.
If you cannot do the repair yourself shop around your area--most shops charge about 300 for a repair like this on your set-I do lots of them here for 200 total.
If the $ cost does not make sense--it is time to buy a new TV--but remember this kind of set has a lot less problems than LCD or Plasma TV sets.....
If you have any questions or need more information let me know--I am here to help people.
Regards, SD TECH
Oct 07, 2009 | Philips 43PP9202 43" Rear Projection...
Need a remote for philips 43pp92 0217 rear projection tv.
Here's a link to order the original Philips remote control for this model (43PP920217) from a major parts distributor:
Philips 43PP9202 17 Replacement Part Remote Control
Feb 17, 2009 | Philips 43PP9202 43" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Hi there, i have an old Philips 43pp925/79 rear projection tv. A few weeks ago convergence ic went bad, so i replaced them both and i replaced 6 resistors. Now there is no bending on the screen but...
You will have to go into Service Menu to realine convergences and What was the STKs numbers you replaced/ and did you go with same part number?I think i have service code for this set will have to look thur my files.
Dec 24, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence problem
Some how instead of posting this to another persons problem it posted here.Hmm Oh well you said you replaced STKs what was their numbers and you may need Service Code also to Realine convergences
Problems with Panasonic PT-53TW53 53 in. Rear Projection HDTV-Ready Television
sounds like the blue convergence IC is bad.This is quite common in all Projections units about 3 to 4 years old.
Jan 31, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Question on Phillips 43pp92 0217
May not be the chips. Try this: go to remote and press 062597 then status to get into the service mode. The menu after that is easy to follow. Hope this helps
Dec 30, 2007 | Philips 43PP9202 43" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
