Question about Samsung RS2534 Side by Side Refrigerator
My side by side samsung refrigerator freezes up and the temperature in the cooling side goes up to 55 degrees F. I wanted to know if it has a defrost heater or not? If it does where is located? thank you
  • 3 Answers
Defrost Heater is a part of the Evaporator Coil. You will need to replace both Evaporator Coil and the Defrost Heater is a part of this coil.
Posted on Oct 07, 2009
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
Refrigerator doesn't get colder than 55 degrees.
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Aug 19, 2011 | Kenmore Refrigerators
Freezer freezes, but refrigerator section will no get beow 55 degrees.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Whirlpool ET1FHTXM Top Freezer...
Freezer freezes fine and at a low setting. Fridge side at maximum setting will not cool lower than 45 degrees !!! ???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 09, 2010 | Samsung 24.8 Cu. Ft. Side-by-Side...
Freezer drain line keeps freezing over
Good day,
Whirpool machines have a very short defrost cycle, as compaired to many brands. This definitely contributes to the problem.
1. Make sure the drain fittings and drain hose to the drain pan are completely open. Not just open, but blown free of any debrise.
2. My experience with many whirlpool products, is ice built up under and back of the drain pan in the freezer compartment. It cannot be seen.
To solve this problem long term, means unplugging the machine, defrosting, and drying it out completely.
24 hours and idealy with a floor fan blowing into the compartment.
3. As well, you wil notice a small round disk clipped to the top of the evaporator. This is the defrost thermostat, and controls the temperature during defrost.
I change and bump this tstat up 5 degrees.
For example, if it's a 50 degree tstat, I replace it with a 55 degree. Or if it's 55 degrees I use a 60 degree model.
You will not be able to buy this as a Whirlpool item, but you can with a little effort, use a GE kit.
The part number for GE replacement kits are for example "WR50X55", the last 2 numbers are the temperature of that tstat, and run in 5 degree increments from 45 degrees to 60 degrees.
A sharp appliance parts house counterman should be able to help you.
P.S. The tstat in Whirlpools are often given in Celsius.
You'll have to convert that to farenheit
Patience in drying the machine is your friend here.
Jack..
Dec 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Refrigerator side not cooling - freezer side icing up
It sounds like your defrost system has failed. There is a timing device that turns on the defrost heater(s) which may have stopped working. Or the heaters or defrost thermostat could be bad.
My suggestion is to find a different repair person who is qualified.
May 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung side-by-side refrig is not staying cold
Look for signs of frost build up on back freezer panel. If there is build up then it has a defrost problem. I haven't had much experience with samsung but I beleive it has a fuse in the defrost circuit on the evaporator and that may be the defrost problem.
Sep 28, 2007 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
426 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
