Question about Linksys Wireless-G WRT54G Router
I had this wireless router for 3 years and never had a problem. I currently moved and the router only works when I plug in the computer NOT wireless. Please help.
    Scholar:
  • 82 Answers
Is the router near a monitor or speakers? Ideally, it should be at least 3 ft away from other electronic devices. Can you see the wireless network SSID? Reconfiguring a router is easy so I wouldn't spend too much time troubleshooting, you can just reset the router to default settings and reconfigure the wireless.
Posted on Oct 07, 2009
My d-link dir 615 wireless router will work fine and then just lose the signal and i have to un-plug the router and then re-plug it in again before it will work again why is this
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 16, 2012 | D-Link DIR-615 Wireless Router
Wireless pci adapter frequent connection drops
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 29, 2012 | NetGear Computers & Internet
Have 2 computers connected to Netgear WGT624NA router via ethernet connectors and have operated well for over a year. Now have gotten DSL and have run phone line to modem and via ethernet cable have...
Have you tried to reset router. It has to be done in order.
1. unplug router
2. unplug modem
3. shut down computer and restart after waiting 1 min
4. after restarting computer plug power back into modem and wait for all the lights to start blinking
5. after the modem is working plug power back to router and plug in the computer with ethernet cable and make sure you have internet,
6. try to link up with wireless,
If this does not work you will have to setup the router for wireless if it is att wireless you will have to call them to give you the password to set it up.
Jan 10, 2011 | NetGear WGT624 Wireless Router
I bought this US Robotics wireless (model 5461 (Maxg)) maybe 3 years ago. I haven't used it in maybe 2 years and now it wouldn't work anymore. I recently switched apartments and computer, it used to work...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Oct 04, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
Likely problems when working in woodworkshop
1.Log into router
7. Move the laptop about 20ft away from any cordless phone or TV sets and try to log on to the internet.
Aug 02, 2010 | Computers & Internet
No connection between the router and the internet. There is connection from the computer to Linksys.
1.Log into router
Jul 25, 2010 | Linksys Wireless-G Broadband Router
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
Jul 12, 2010 | NetGear WGR614 Wireless Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
When i plug in my router the ip address changes and i cant access net
This issue is possibly due to a configuration problem
1.Log into router
Here is the link for the DIR-330 your model number did not list:
http://www.dlink.com/products/?pid=564
Jun 21, 2010 | D-Link DIR-300 Wireless Router
Keep getting kicked off
when sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
May 31, 2010 | Belkin N Wireless Router wireless router
Linksys Wireless-G WRT54G Router Logo
47 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
