Question about Nintendo DS Lite Console
Nintendo DS replaced case
AFTER THE REPLACEMENT CASE WAS REPLACED ALL THE UNIT DOES WHEN YOU TURN IT ON IS, TURN ITSELF BACK OFF
  • nev g Aug 01, 2008
    how do you disconnect the wire at the hinge
    thanks neville
Hi. Same thing happened to me. Stay on this website and search for "Nintendo DS Power On Fault".
Wendy
Posted on Jan 04, 2008
    Problem Solver:
  • 13 Answers
The battery may have run out, use the charger that comes with the console.
Posted on Jan 03, 2008
2 Suggested Answers
  • 19 Answers
SOURCE: Nintendo DS New CASE Fitted
Hmm, when you removed the top screen's flex cable, were you very gentle indeed? It could have been torn when pushing it through the metal barrel in the hinge and working it into place through the slot in the case. Otherwise it may just not be pushed fully home into its connector socket.
Posted on Jan 01, 2008
Bottom internal touch screen cracked on ds lite-how do we get it repaired
Unless you are comfortable of taking it apart yourself and ordering the part online.
I'd suggest going here.
http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Mar 03, 2011 | Nintendo DS Lite Console
Nintendo ds
First remove the new case and see what you get - if it all works fine then the case must be pinching a cable or pressing on something it shouldn't. Check the unit with AC only or battery power only. The faint click is probably the power switch membrane clicking across - probably indicating that the switch itself is fine - but check at least visually and with a meter if you can. the most likely causes of the problem if removing the case again does not get it working are; Loose connector - probably where the screen hinge is, or where those cables connect to -check anything that you could have moved. Is it an official original case? some cheap copies may be badly fitting, although I found no info on any problem like this so far. If you have a card inserted, try with a different one or without one. check nothing got in the card slot and no pins are bent - especially if you just put a card back in after replacing the case. Especially could be problem if your DS was set in Auto start-up mode before. Possibly unconnected to the case change, the power supply or battery could have failed. Check through this link and see if it helps identify if that is the problem. Do you get any power or charging lights? http://www.nintendo.com/consumer/systems/ds/trouble_power.jsp nintendo do not recommend it, but it may be worth removing and reinstalling the battery in order to reset the unit. proceed with care. Here is the link to the manual if you need it; http://www.nintendo.com/consumer/downloads/ds_english.pdf Hope this helps - please post back with more details :)
Aug 15, 2007 | Nintendo DS Console
Ds lite hinge is broken is there an easy fix
There web sites where you can get a new case for your DS. When searching try using : nintendo ds lite replacement shell or nintendo ds light case modding
Feb 25, 2009 | Nintendo DS Console
Damaged ds cartridge
contact manufater and check warranty
Jan 02, 2009 | Nintendo Pokemon Diamond for DS
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
Hi after case replacement i cant get bottom touch screen to work
is this on a lite or ds you may have damaged one of the connectors on the board i may be able to help with repair email onkenfree@live.co.uk
Jul 01, 2008 | Nintendo DS Console
Stolen ds
Turn in the theft to the police. They check serial numbers from pawn shops. Go luck thought, they really don't care.
Jan 12, 2008 | Nintendo DS Console
Dec 24, 2007 | Nintendo DS Lite Console
Nintendo DS Lite
Well something more appropriate i guess would be my ongoing issue with DS's that have had screens replaced.
if you could describe something for me
as the unit will not power ,,, plug in the charger, if it is as i suspect you will get an orange light illuminate for 1 second, after it goes off the unit is unresponsive until you unplug and replug the charger.
if this describes your problem i would be most interested to hear weather you used the ORIGINAL screen or if it is a replacement screen
thanx
Nov 14, 2007 | Nintendo DS Lite Console
Nintendo ds to screen broken
Hi, replacing the original nds upper screen is a fairly straight forward procedure, you need to remove the 4 x small plastic plugs located in the corners of upper screen, then remove the 4 x phillips screws, the top outer back part of the case will seperate and you can gain access to the screen. Firstly remove the small screw holding down the right hand pcboard to gain access to the ribbon connectors, release the larger flat connector by hinging the clip up, slide the ribbon out, underneath you will see a tiny connector, gently ease the small clip back towards the ribbon, prising a little each side at a time, remove the ribbon and then you can prise the screen from the case.
These guys sell the replacement screens www.ps2laser.co.uk prices are very competitive and offer next day delivery!
Nov 08, 2007 | Nintendo DS Console
Nintendo DS Lite Console Logo
59 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
