Question about Porter Cable 371K Electric Sanders & Polishers
Porter cable polisher5 7424 only works at max speed
  • 2,176 Answers
It could be that the variable speed module is malfunctioning. If it is the part number is 886978 and lists for 12.27. I would check for a buildup of polishing pad inside the handle area and clean thoroughly before ordering any parts. You can view a breakdown at Dewaltservicenet.com
Posted on Oct 10, 2009
Where can I get a wiring diagram for a Porter Cable20volt battery
images for Porter Cable20volt battery wiring
Power Tools - Porter-Cable
www.portercable.com/20Volt
Get Linked with the Power and Performance of the 20V MAX* system of tools. Powered by a lithium ion battery platform which delivers the performance and ease ...
Shop PORTER-CABLE 20-Volt Max Lithium Ion Battery, 2 ...
www.lowes.com/pd_472386-79992-PCC680LP_0__?productId...
Lowe'sPORTER-CABLE 20-Volt Max 1.5-Amp Hours Power... ... PORTER-CABLE 20-VoltMax 4.0-Amp Hours... ... PORTER-CABLE 2-Pack 20-Volt Max 4-Amp Hours...Missing: diagram
Jan 20, 2016 | Porter Drills
Porter cable
DO NOT leave it that way - that fuse is for YOUR protection, and the protection of your family and neighbors.
That humming is probably an byproduct of the speed control, not too much to worry about. The vibration should go away almost entirely when you reset the wheels to run true and dress them to balance.
The capacitor is your starting capacitor - its voltage rating is completely unimportant - that's a max voltage rating, and they only wanted to stock one capacitor, not have one for the 120V versions and a second one for the 240V versions.
Did you by chance start working on this grinder while it was still under warranty?
If the wheels turn freely when the power's off, and if the grinder doesn't get awfully warm when it's in use, then I'd think that the problem is within the speed control board.
Feb 10, 2014 | Grinders
How do I remove the rotating disk on a porter cable polisher model 7336
You have to use a wrench behind the disk for a stop and then unscrew from the housing Porter Cable
Feb 23, 2013 | Porter Cable Porter-Cable Variable Speed...
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
Dec 17, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
Jan 24, 2010 | Porter Cable 75182 Variable Speed Router...
BN200A porter cable brad nailer. have tried
check for a broken driver blade, also make sure of the proper nail guage for the tool. Let me know if this is not the case and I will find you a breakdown for the tool for further inspection.
Nov 06, 2009 | Porter Cable 18 Gauge 2 " Brad Nailer Kit...
Variable speed quit working
You would need to replace the switch, give me a model number and a location with zip code and I will try and find one locally for you, Its not that hard
Apr 25, 2009 | Porter Cable Variable Speed Quik Change...
Porter Cable 371K Electric Sanders & Polishers Logo
98 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
