Question about Canon ImageRUNNER 3570 Copier/Printer
Error code E602-0001 on Canon IR 3570
What is error code E602-0001 and how do you fix it on Canon Imagerunner 3570?
Tried to print something to it via the network, and it just stopped. Only thing on the touchscreen is "E602-0001"
  • 117 Answers
Your canon image runner Imagedrum problem
Posted on Oct 08, 2009
Hi, this code is a hard disk failure. I have heard annecdotal accounts of it being other components having failed - but essentially the failed component is preventing the disk from mounting properly or the disk has failed. You will probably need a replacement hard disk or, at very least a reformat and re-installation of software. I suggest a canon engineer for this - sorry.
Good luck to you.
Posted on Nov 10, 2009
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon copier 4570 error code e000007-0000
canon ir 4570 error solution for Code E000007-0000
Nov 25, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon iR 4570 Error code E00007-0000
it might just be a power spike in which case your machine just shot an error while it protected itself...
try the following...
press additional functions
press 2 and 8 at the same time
press code error
press copier
press function
press clear
press error
press ok
press reset
if that doesn't work then call a tech.
May 19, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon Imagerunner 3570 error code
if u r still having this problem with the imagerunner 3570 u can try this:
press * 2&8 together then * again
go to function
then to clear
select eroor then ok that should take care of ur issue
Jun 08, 2008 | Canon ImageRUNNER 3570 Copier/Printer
1,882 people viewed this question
old marine
old marine
