How do you operate the whole house fan in order to save heat loss
Recently bought this one floor house with a whole house fan. Fan is in hallway by bedrooms,but in the attached garage there are two large openings in the ceiling....air flows up when garage door is opened and into the rest of the attic, especially during the winter months. Last winter I covered insulation on top of the fan mechanisms in the attic but these openings in the garage were still there. Is a lot of my heat being lost because of this situation? Previous owners didn't explain much about the process and I have no manuals. How do I solve my problem to make it more energy efficient.
  • 22 Answers
Make covers for garage opening with hinges open in summer close in winter .
Posted on Oct 09, 2009
Indoor blower won't shut off on heat pump
I would look to replace a relay that is not shutting off or replace the thermostat itself.
Nov 14, 2015 | Honeywell Heating & Cooling
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
2004 Dodge grand caravan front heater. No defrost of floor heat.
Try scraping ice off the "whole glass area." before you leave the house.
Dec 23, 2013 | 2004 Dodge Grand Caravan
Kenmore Coldspot Model 106.71182100
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
May 29, 2012 | Kenmore Refrigerators
We have recently purchased an older home, built in 1931. There is a whole house fan in the attic that we would like to get working again. We do not know when the fan was installed or who made it - however,...
What and interesting situation. I have seen installations like what you describe, but not in a residential application. Industrial applications that had very high ceilings and in very old apartment buildings, But not in single family resident. I suspect, that the previous owners "acquired" it through unusual circumstances.
In any event, 1/3 horsepower electric motor is not that hard to find. The real key is getting the right rotation, so the blades will pull the air up and out instead of in and down. Remounting a new motor coupled with the right pulley size for a fan belt ,can control the speed of the fan. Rarely are hold house fans direct drive. Which may be the case with yours, I don't know.
As far as a new 1/3 Hp motor is concerned, I would recommend Grainger Industrial Supply
http://www.grainger.com/Grainger/wwg/start.shtml. They have locations throughout the country and their staff is knowledgeable. They can probably help you with designing a belt & pulley system, to control the speed, if necessary. Keep in mind, 2-speed motors are also available.
Redesigned properly, you can do away with that horrendous shaft.
Hope this helps steer you in the right direction. If nothing else, food for thought.
Apr 28, 2011 | Heating & Cooling
We do not know how to turn the whole house fan on. Does it work through the thermostat on the walll for the air- heat switch?
To turn on your whole house fan, got to you thermostat. Open the door and look for where it says fan, most will have a selector switch to select "auto" or "on". You want it "auto for it to work properly with your furnace and or central air. If you flip it to "on" it will run 24 hours a day none stop, warning this may shorten the life of your fan a little.
Jul 29, 2009 | Ventamatic Direct Drive Whole House Fan...
No air or heat blowing from vents
if the fan is blowing this could be a problem with the climate controll switch that changes the direction of air from floor to defrost to vents, some are vacuum controlled through a vacuum operated mechanism that opens and closes a door in the vents which redirects the air to different places.
Mar 24, 2009 | 1999 Volvo S80
Heater fan regulation
2002 Grand Caravan. The rear heater also has a resistor for the fan speed control.(3 speed) It is located under the rear passenger side plastic cover. You can take off the rear tail gate lower plastic piece and this will let you pull out the side panel. You can reach in and take out the two screws that hold in the resistor and unhook the wiring adapter. You do not have to take off the whole side panel as you can reach in from the back. The resistor unit can be bought at you local dodge dealer.
Nov 30, 2008 | 2002 Dodge Grand Caravan
Shuting down\off after several minutes of operation.
This thermal switch may be of the type where it is saving power by turning off motor when air is sufficiently cooled. You obviously want the air cooler, so you can place a wire across the two terminals of that switch to defeat the power save. If the switch is to prevent motor over-heating, however, then you cannot jumper that switch. Do this test: open back to locate switch. if switch is located directly on motor housing, then that switch is cannot be jumpered out. if switch is located in air stream, then it may be possible to jumper it out. Try the jumper and observe for many operations of fan useage to ensure jumper is safe. Ensure no bare wires or electric terminals exposed when done.
Sep 03, 2007 | Patton Electric U2-20 Box Fan
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
