Question about Hitachi 50SBX78B 50" Rear Projection Television
Owners manual I need an owners manual for Hitachi 50SBX78B
  • stepman Dec 24, 2007
    flickering picture on tv all channels
    President:
  • 1,294 Answers
Click on Hitachi (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
Posted on Dec 28, 2007
    Genius:
  • 1,153 Answers
You can find info at ctechnicians.com
Posted on Dec 24, 2007
Hitachi tv turn off by itself when i get hot, how do i fix it?
Check for any air path obstructions and see if the fan is working, if not it needs replaced or checkd out. You can try and put a fan behind the unit to keep it cool this will sometimes work but the main reason is the set is getting to hot and it shuts itself down to protect itself from a failure.
Aug 14, 2011 | Hitachi 50SBX78B 50" Rear Projection...
I have the same problem as above. I have a Hitachi 50SBX78B and it was working great until some water from the plant on it got into the screen. Now the red light comes on for a split second, then goes...
Unless the main board is checked the damage to the board cannot be accessed. so open out the set and check on for any failure of fuse or fusbile resistors that could have opened out with the water shorting.
If water is still found use a dryer to warm off the moisture.
It area of the water spill must be checked for the possible damage
Sep 15, 2010 | Hitachi 50SBX78B 50" Rear Projection...
Tv will not power on
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Nothing on my TV
This set has CRT guns. 3 of them. No bulb.
Check and see on this site what others have suggested for your problem.
Without seeing it I'd say main AC fuse
Mar 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Lamp flickering
Well jumping has nothing to do with lamp so called bulb.
You have what I would call a cold solder joint.
You're going to have to open the set and tap gently to see were it is comming from. If you know anything about soldering they you will know it is not that easy.
Once you think you have found the place were it seam's to be the place were it make's it jump more often, start again to make shure that's the spot and not the hole area.
Then remove the board and resolder,
Good luck
What About Bob
Timmins, ontario
Home of Shania Twain.
Mar 15, 2008 | Hitachi 50SBX78B 50" Rear Projection...
No power
You need to check E991, E994, Q777, for more info ctechnicians.com
Jan 09, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 50SBX78B 50" Rear Projection TV
If the power supply board is the only thing affected, I would suggest calling PTS:1-800-844-7871 and give them the model and what you are looking for. This would be the simpliest thing to do. They rebuild boards and maybe more cost affective than trying to repair yourself. Hope this helps!
Sep 07, 2007 | Hitachi 50SBX78B 50" Rear Projection...
Pink Dot in center of screen.
Well, You have a bad engine, so what other's called lcd projector motor.
This will cost you, the engine states at about $500. I've seen this problem and right after I've change the engine for some
F#$% reson the bulb when, twice on me, that's another $400.
Good Luck
What About Bob
Timmins, Ontario
Sep 24, 2006 | Hitachi 50SBX78B 50" Rear Projection...
Televison & Video Logo
205 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
