Question about GE Refrigerators
I am replacing the defrost heater (new 2 element part) in my ge model gsl22jfphbs refer. How do you get at the location behind the light bulb where it all plugs in? Thanks, Merch
  • GE Master
  • 1,606 Answers
The correct element , for the model number you gave , is WR51X10101 . This part is plugged onto the existing wires ( pink and blue ) . If the blue is too short , then an extension comes in the kit , with longer wire and a crimp on connector . You do not unplug anything except for the 2 wires on the old element .
Posted on Oct 08, 2009
Testimonial: "I replaced the heater yesterday. Thanks for your help!"
Hello. We just moved into a new home. The house came with a GE side by side (GSH25KGMCWW) refrigerator. The freezer works great! But the refrigerator is not cold; it's not even cool. Can anyone...
Hi,there
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 Phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
I hope this will in solving the problem....
May 08, 2011 | GE Refrigerators
Defroster not working
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Jan 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE model #GSS201EMBWW is not defrosting, checked defrost heater and it was burned out. Replaced with new 2 heater design and now it burns all the time, which is most likely what burnt the other 1 out....
This is how the defrost works . I have NEVER found a defrost problem associated with a bad main control board since these computerized GE's came out in 2000 . Lots of thermistor problems , lying to the board , causing different problems .
Your GSS model refrig does not have a defrost timer . It works off of the main control board . Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Aug 30, 2010 | GE GSS25SGMBS Side by Side Refrigerator
Won,t get cold freezer side not freezing it is a ge side by side . ice is present at the back of freezer side
The problem is most likely the defrost heater element(s) and/or the defrost timer. The defrost heater element(s) are located with the evaporator core behind the access panel inside of the freezer, and can be removed, tested with an ohm meter, (any reading other than infinity would most likely mean the heater element is functional) and replaced if necessary. The defrost timer can be located inside of the refrigerator, or outside of the refrigerator behind the front kick panel, or behind the rear access cover on the back of the refrigerator.
Usually if the evaporator core is freezing up and not allowing air to flow through the evaporator core, (necessary for the system to function properly) then the defrost timer is most likely working and the defrost heater element(s) would most likely be at fault.
Always place a towel on the bottom of the freezer and use a blow dryer to defrost the evaporator core and never use any sharp or hard objects to pick away the ice or the evaporator core can be damaged and the refrigerant will be leak from the system.
I have included some images to help assist you including an image of a defrost timer that is located inside of the refrigerator, and a new defrost heater element or defrost timer can be purchased from an appliance parts distributor.
Let me know if you require any further assistance.
Jul 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I would like to test the defrost heater
the defrost heater is located behind the back wall of the refrigerator. remove the screws and any shelf supports required to remove the back wall. Depending on which model you have, you will have either one or two elements. Test for continuity.
Apr 09, 2010 | GE HSM25GFTSA Side by Side Refrigerator
Defrost heater not turninh on
That model has what is called a adaptive defrost on it this fails very often it is located inside the ref under the control panel, The only other possible cause would be a defrost thermostat, this is located near the heater.
Aug 11, 2009 | Maytag MSD2650H Side by Side Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
153 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
