Question about HP Photosmart C5180 All-In-One InkJet Printer
Says we need new ink cartridge and it has a new ink cartridge installed already
    Sergeant:
    Champion:
  • 269 Answers
Are these refilled cartridges?
Posted on Oct 07, 2009
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Ink levels lights flashing but ink is full
Might be cartridges are refilled.
You may got doubt why its not measuring the ink levels?. When printer found new catridge(printer/system based on design) will treats that new cartridge installed & estimated level will display fully.After couple of print outs printer/system will displays estimated ink levels depend upon the ink usage. But there is no mechanical ink level sensors or any other device for mesuaring the levels..Once the ink level trated empty you need to replace new cartridge straight away,if you refilled the same catridge it wont measure the levels, because of the cartridge data code already stored in printer. ..
Nov 02, 2011 | HP DeskJet F4280 All In One Printer InkJet
My printer keeps printing blank pages. I have cleaned the heads, re-started the printer, restarted the computer, checked all the cables and the problem persists.
You may need to purchase new ink cartridges and install new ink cartridges. take in the old ones into your computer store to make sure you get ink cartridges that will work in your make and model of printer.
If however you have already installed new cartridges then you will want to make sure that the plastic sticker that is some-times placed over the ink cartridge's contacts is removed.
Usually one will need to perform several deep clean cycles to get the ink to saturate the system and print well. Print test pages as you go.
Take care!
damnor01
Jul 19, 2011 | HP Officejet 6500 Wireless All-in-One...
I refilled my black cartridge of Pixma iP 1600. I have done it 3 times before and it worked perfectly until yesterday. Now when I refilled it the 4th time, the yellow LED blinks 5 times and then the green...
The manual for the PIXMA iP1600 says the following concerning the 5 blinks:
The ink cartridges are not properly installed, or a non-supported ink cartridge is installed (the ink cartridge EEPROM data is abnormal). Install the ink cartridges properly. Or, confirm that the supported ink cartridges are installed.
If you haven't already I would take a look at the electrical contacts on the cartridge to make sure they are clean (free of dust and ink) and then reinstall them in the printer. If the printer gives the same error, it's time to buy a new cartridge. 3 refills from a cartridge is not bad at all.
Hope this helps,
Steve
Feb 10, 2011 | Canon PIXMA iP1600 Printer
Hi. My printer will not recognize the magenta ink. I tried replacing it with 3 different new ink cartridges, but when I try to make the printer charge the new ink, it does nothing and says I'm out of...
Hi
Some ink printer had ink resetter and just go to ink set up.
If your printer have ink resetter, do it otherwise it will not recognized new ink installed.
If not, some new ink cartridge when the tape is remove, there are cases that the sticky leaf on the ink cartridge, just rinse it with warm water or alcohol to detect the ink cartridge. Turn off your printer and your computer. Then return the ink and open your printer and computer to print again.
Note : Use only ink that is compatible with your printer because it you use other cartridge it will damage the chip set of your printer and it will not recognized any cartridge at all. SO beware.
I hope it helps you.
Jan 12, 2011 | Epson Stylus Photo R1800 InkJet Printer
The black ink will npt come through
If you have just installed a new ink cartridge and an ink low or Replace ink cartridge message is still displayed, the cartridge may be incorrectly installed.
Follow these steps to make sure the cartridges are correctly installed:
  1. Press the On button to turn on the Epson Stylus, or (if already on) press the Setup button.
  2. Select Maintenance and press OK.
  3. Select Change Ink Cartridge and press OK.
  4. Open the scanner.
  5. Open the cartridge cover.
  6. Press down all the ink cartridges until they click into place to make sure they are properly seated.
  7. Close the ink cartridge cover and push it down until it clicks into place.
  8. Close the scanner.
  9. Press OK to begin charging the ink. This takes about 2 minutes.
    You see a message on the display screen when ink charging is finished.
    Caution:
    Never turn off the Epson Stylus while ink is charging or you'll waste ink.
    If you remove an ink cartridge for later use, protect the ink supply area from dirt and dust and store it in the same environment as the Epson Stylus with the label facing upward. Note that there is a valve in the ink supply port, making covers or plugs unnecessary, but care is needed to prevent the ink from staining items that the cartridge touches. Do not touch the ink cartridge ink supply port or surrounding area, and do not store the cartridge upside down.
    If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 16, 2010 | Epson Stylus NX400 InkJet Printer
My epson stylus cx6000 printer keeps showing -(install the ink cartridges) and I have already put in new ones. The code is E-02.
f you have just installed a new cartridge and you still see an ink related error message, the cartridge may be incorrectly installed. Follow these steps to make sure the cartridges are correctly installed:
  1. Make sure the Stylus CX is turned on.
  2. Check the photo viewer screen to determine which cartridge is incorrectly installed. Then do one of the following:
    • If printer shows the ink cartridge is expended, press the cp_button_6.gif Start button.
    • If the printer shows the cartridge is low on ink, press the Setup/Utilities button. Press the cp_button_41_er.gif or cp_button_42_er.gif button to select Press Start to change cartridges. Then press the cp_button_6.gif Start button.
  3. Press the cp_button_6.gif Start button again.
  4. Lift up the scanner, then open the cartridge cover.
alert_caution.gif Caution:
Never attempt to open the cartridge cover when the print head is moving. Wait until the cartridges have moved to the replacement position.
  • Press down all the ink cartridges until they click into place to make sure they are properly seated.
  • alert_note.gif Note:
    If a cartridge is properly seated already, you may not hear a click.
  • Close the ink cartridge cover and press it until it clicks into place.
  • Close the scanner.
  • Press the cp_button_6.gif Start button. The Stylus CX charges ink for about one minute and displays Charging Ink on the photo viewer screen until charging is finished.
  • alert_caution.gif Caution:
    Never turn off the Stylus CX while the Charging Ink message is displayed or you'll waste ink.
  • Press the Setup/Utilities button to return to the previous mode, if necessary.
  • Aug 26, 2009 | Epson Stylus CX6000 All-In-One InkJet...
    Black ink cartridge wont print, have installed a new ink refill still no joy. Will print in all other colours.
    Well if you already installed a new black ink cartridge and still wont print, then try cleaning your printer head. It can be that the some ink was hardened and got stuck preventing you to print a black color.
    Jul 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
    I replaced my new $40 cartridge with another new cartridge and it worked.
    Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
    Ink cartridge red light
    need original canon ink cartridge not generic
    Jan 02, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    HP Photosmart C5180 All-In-One InkJet Printer Logo
    79 people viewed this question
    Seeker5211
    Seeker5211
