Question about EuroTech EDV278 Extra Large Dryer
DRYER MODEL EDV 278 EL. Intermittent rubbing type noise coming from drum area. Belt has been checked and is in good condition. This dryer has no idler or tightener pulley. Is it possilbe to obtain or download the repair manual for this dryer and a parts list. Could the sound come from the drum support pads at the front of the drum. The rear nylon support blocks appear to be in good condition. Dryer is 4 years old and sees a lot of use.
  • 2 more comments
  • prefonr Oct 07, 2009
    Sounds easy but where is the access panel. The front of the dryer is one piece of sheet metal with no screws visible. If it is something like my old GE dryer, I have to take the complete cabinet apart in order to get to the drum and rollers. Again I ask, can someone guide me to a maintenance and parts manual for this dryer?
    The noise is something that appeared a week ago. No maintenance was ever done on this dryer. I can't see how it could have come out of alignment by itself. I have to conclude that one of the rollers is worn out. Will have to bite the bullet and take it apart. However, I still do not know how to order the parts since I do not have a parts list.
  • prefonr Oct 08, 2009
    replies received were very generic and not specific to my Eurotech EDV 278 EL dryer. What I really need is to find the technical and parts manual for this dryer. From these I may be able to see how to disassemble the dryer to get at the problem which is suspect is a damaged roller supporting the front of the drum. I get an intermittent rubbing noise from that area.
  • prefonr Oct 09, 2009
    Unfortunately you are not familiar with the dryer in question. There is no idler pulley. Thank you for the lead to obtain a parts manual.
    President:
  • 1,922 Answers
First ceck your "IDLER" puley, then your drum glides or rollers,whichever type the unit uses, then the rear drum bearing, if these don't checks don't quiet the unit you can get a manual and or the parts from "AppliancePartsPros"web-site or contact them at 1-877-477-7278, but I think you'll find your problem
Posted on Oct 09, 2009
  • 6,826 Answers
Remove the access panel,and look for a roler to be bad(broken)or missing,it coul have been damaged when the belt was installed,or the drum was not set corectly in the rollers.There also could be a obstuction in the way of the drum,but most likely,the drum,is not in the rollers corectly.I hope this was helpful somewhat.
Posted on Oct 07, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Oct 07, 2009
    You will have to disasible the dryer most likely,There is so many models,and changes,hard to keep up with all the different makes and models,also.I think the top ,just pops up,grab it and **** it upward.It will have metal clips holding it down,like the old dryer you had.To view the bottom,just tilt it over.If a belt was installed,the drum may be rubbing,or off the roller.Or a roller is ceasing up.
Admiral dryer makes a rubbing sound when rotates
Hi J. Rummel...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Mar 19, 2013 | Admiral Dryers
417.93042201 I have a Kenmore dryer that is making an intermittent thumping noise, squeaking noise and one that sounds like there's sandpaper rubbing up against the inside. The dryer still dries,...
Hi mcquckin389...
If you can do this yourself then you can save a ton of money
On a scale of 1-5 in difficulty...I would give it a 2.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
This is a FREE answer, Please take time to rate me
Jul 01, 2011 | Kenmore 73952 Gas Dryer
Frigidaire front loading dryer model LEO2152ESO....runs fine but all of a sudden it just started making a rythmic "thumping" noise when turned on...
Hi ckteaque...
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
May 21, 2011 | Frigidaire GLEQ2152ES Electric Dryer
The dryer is still working but it makes loud noises sounds like something may be rubbing and maybe like a belt may be hitting something.
If you have a front loading machine,
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 06, 2011 | Dryers
My Maytag Atlantis MDE7600AYW dryer is making a squeaking noise like a bearing going out. Is this a servicable area? Can I access the area to "oil" it? Thanks, - Ryan
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Oct 13, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a GE electric Dryer Model EED20001 WWD Making a repetitive scraping noise. Sounds like its coming from the motor area. Took the dryer apart and the motor seems to be turning fine belt is good. Any...
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 09, 2010 | GE Dryers
Dryer is making a clunking noise, even when empty
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 28, 2009 | Dryers
Rubbing noise, seems like the drum is off set possibly.
Your problem sounds like drum rollers are worn and may have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and alignment problem.
Good Luck,
I hope this helps
Please rate me,
Thank you
Dec 01, 2009 | Washing Machines
Neptune dryer tumbler rubs very noisily against its mounting in the upper right (as I face the controls). The tumbler (basket) has a deep gouge where it is rubbing against the housing.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
EuroTech EDV278 Extra Large Dryer Logo
148 people viewed this question
Top EuroTech Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
