Question about Samsung SGH-D900 Cellular Phone
Power my d900 started running out of much too quickly the other day, i.e. from full to nothing in about 5 hours with only one call. i went out and bought a new battery but it has made no difference. help.
    Problem Solver:
  • 5 Answers
Its a hardware fault with the phone. it sounds like it needs a new pa amp so its either a fix by your local repair shop or new phone time.
Posted on Dec 26, 2007
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
Changed oil in bike, started right up to move it where i then changed the oil, went to turn the key to the on position, NOTHING, none of the gages come on, fuel pump doesnt prime either.
Hi Richard, and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Good luck and have nice a day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 04, 2012 | Motorcycles
Have full power and go to turn key it does not crank, leave and come back 8 hours later and it starts?? 3 Days later running errands run in run out go to start again nothing but have full power???
check the crank shaft position sensor located on the upper drivers side of the bellhousing.Check the plug and wires too.if its going bad it will create a no spark condition.
May 28, 2011 | 1988 Jeep Cherokee
I just bought a 1990 daihatsu feroza and it has a brand new battery in it. i picked it up at about 10 oclock yesterday and drove it for about an hour back to my house. i then started it about 5 or 5 more...
This definetly sounds like an alternator problem........but to definetly check this.....grab a multimeter, and check the voltage at the battery whilst the engine is running/idling, the voltage should be around 13.8v and 14.2v,,,,,,,let me know how it goes !!
May 18, 2011 | 1990 Daihatsu Rocky
Samsung d900 . battery run on half an hour during call and if it is sleep mode then till 4 hours only
Please check the adapter voltage and the charging of the battery when placed for full charging. Once the charging has confirmed to be full remove and try once again to see if the phone indicates. Now clean the terminals and connect. If the battery does not last , it is possible that it must be replaced. Please confirm with a battery from a friend and buy ONLY the original with warranty.
Apr 26, 2011 | Samsung SGH-D900 Cellular Phone
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Samsung SGH-D900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
