Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
How to take my chuck off broke tool off inside chuck
  • 672 Answers
The screw that holds the chuck on, is in the bottom of the chuck itself. If there is something jammed in the chuck, it must be removed in another manor. If the chuck is jammed, I have used two pair of channellocks to open the it.
Posted on Oct 07, 2009
Broke bit inside chuck and piece is lodged in there now. Pulling out on chuck release does not allow broken part of bit to come out. Do I need to take drill apart or remove chuck to get broken bit out of...
TAKE THE OUTER CHUCK PEICES OFF THE IMPACT!! THERE WILL BE A C-CLIP, WASHER, SPRING AND ONE OR TWO BALL BEARINGS AND THE OUTER HOUSING, IN THAT ORDER! WITH ALL OF THAT OFF, MOUNT THE ANVIL IN A BENCH VISE WITH BRASS JAWS OR BETWEEN TWO PEICES OF WOOD, UPSIDE DOWN!!!!!!!!!!!!!!! THE TRICK IS TO HAVE THE BIT FALL OUT OF THE CHUCK ONCE IT IS LOOSE!!!! NOW WITH IT MOUNTED IN THE VICE AND PRETTY TIGHT, TURN THE TOOL ON UNTILL IT FALLS OUT, IT WORKS GREAT IF HAVE DONE IT ABOUT 75 TIMES!! MOST PEOPLE THINK I'M A WIZARD!! BUT IT'S REALLY EASY. WITH IT MOUNTED SOLID IN THE VISE THE ANVIL HITS SO FAST AND HARD IT VIBRATES THE ANVIL, IF YOU DO NOT REMOVE THE BALL BEARINGS HOLDING THE BIT, YOU WILL BE DOING THIS ALL DAY. SOMETIMES, IN THE CHEAPER BITS IT WILL ROTATE AND GALL UP SO BAD THAT IT WILL NEVER COME OUT, IN THAT CASE YOUR BUYING A NEW ANVIL ASSY. JIMS TOOL SERVICE
Jan 11, 2011 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Want a operating manual for saw zall 6523-21....blade broke in saw....want to know how to get broked blade out of saw
I believe that one has the quick release chuck, right? The one where you rotate the outer ring to release the blade? I would turn it to the release position with it pointing towards the floor and tap on the side of the chuck with a screwdriver handle or small hammer. (you may need help with this due to lack of extra hands, and of course, unplug it first.) Good Luck.
Mar 07, 2010 | Hand Tools
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
My chuck is broke , on my 18v makita cordless drill , how do i fix it
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
Sep 17, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt Drill DC728. Chuck came out of drill body
I would clamp chuck in vise and use a chuck key or a Channel Lock Pliers to loosen the chuck.
Jun 08, 2009 | Dewalt Drills
Drill bit Stuck (and then broke off)!
Keyless chucks have two parts (see pictures) when the drill is in operation both parts spin. Assuming you put the drill bit in and tightened the keyless chuck by hand, put on a work glove and grasp the part of the chuck at the front of the drill, grasp the other part and twist the front part anti clockwise.
If this does not work you can hold the front of the chuck and reverse the direction of the motor as if you were unscrewing something, then pull the trigger. If your hand does not grasp the chuck tight enough it will slip, hence the glove. If this does not work you may have to hold the front of the chuck in a vice or with caliper pliers and again the pull the trigger with the drill in reverse.
All this depends on what you used to put the drill bit in with your hand tight or held onto it with something else. Whatever was used should be enough to loosen the chuck
Hope this helps.
If it does let fix ya know.
Cheers
Les
Feb 02, 2009 | Dewalt DW056 18 Volt Cordless Impact...
DeWalt 12V cordless the chuck mow backs out under load
That depends take the chuck off and see if you can see a part of a screw in the spindle. If so try and turning it with a small pick to remove it. It sounds like all you possibly broke was the chuck retaining screw. You can go to a repair center and pick one up relatively cheap or go to Dewaltservicenet.com and type in your model number to look at a breakdown for this part. Let me know if anything different, I take it also that the tool runs and sounds OK otherwise?
Jan 22, 2009 | Dewalt Drills
Hitachi cordless drill, removing chuck
Replacing the chuck on a drill is simple when you know the trick. I worked at a tool rental center while attending college and learned how to repair many tools. Open the chuck enough to remove the screw that you will see inside the chuck. It will most likely be reverse thread. The chuck is threaded on the shaft so just simply close the chuck on an allen socket and impact off with air or electric impact tool. If you do not have an impact tool close the chuck on-to the largest allen wrench that will fit into the chuck.(with the long part of the allen wrench projecting out) You will need to set the drill into a vise or strap to work-bench, then strike allen with hammer. Most chucks are removed with one quick impact of the hammer, counter clockwise. Do not squeese the drill too tightly with vise, we used a piece of leather to protect the drill. Good luck. Enjoy
Dec 16, 2008 | Hitachi NV45AB2S Coil Roofing Nailer
Chuck Replacement
Hello Mike-To remove the old chuck, you'
ll need to open the jaws all the way and l;ook inside the chuck for a screw that holds the chuck onto the motor shaft. That screw has a reverse thread which means that you'll need to hold the chuck tight while using a screwdriver to turn the screw in the forward direction. After the screw is removed, p[lace a large allen wrench into the chuck and tighten it. Then using a hammer handle, rap the allen wrench in the reverse direction for removal. Then call Alltrade Tools @ 1-800-423-3598, give them your model number so they can provide you with a replacement chuck.
Jul 31, 2008 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Drill chuck locked up
Your problem is with the screw holding the chuck onto the shaft. That screw if a reverse thread and needs to be tightened in reverse direction.
Sep 16, 2007 | kawasaki 19.2V 4 Piece Cordless Tool Kit
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
338 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
