Question about Frigidaire FGF378AC Gas Kitchen Range
Gas oven not lighting glow plug lighting but no gas releasing
Not it has not still waiting for your advice your site said it had a free trial but all im getting is a request for a credit card number whats up with this?
Posted on Oct 08, 2009
Oven range will not light. glow plug seems to be working
You need a new glo-plug. They still glow when they go bad but not enough to ignite the burner. It's a fairly easy DIY project.
May 28, 2012 | Kenmore 70102 Gas Kitchen Range
The Glow Plug is glowing, but oven will not light up.
This may sound strange but it is most often the glow plug that is bad. What happens is as the ignitor (glow plug) ages the resistance internally rises, this rise gets to a point where it limits the electrical current just enough that the valve no longer opens.
May 05, 2010 | Electrolux Ovens
Oven will not light, the glow plug will work and get how however gas will not be released to light the burner.
I would like to add that I have already installed a new glow plug in this unit.
Jan 30, 2010 | Amana Ovens
Gas range oven is not heating to temputere
If the oven is lighting normally the tempurature sensor is probably bad. If the igniter glows but doesn't light the oven then the igniter is faulty and needs replaced. A faulty igniter can still glow but not get hot enough to release gas into the burner tube.
Nov 30, 2009 | Kitchen Ranges
Oven wont light
Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
Oct 10, 2009 | Imperial Commercial Cooking Equipment...
Glow plug comes on and smell gas but no fire
That is a bad gas valve. Need too change it out. The glow bar is working but the valve is not opening.
Sep 02, 2009 | Tappan 30IN ELEC IGNa Oven
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint oven
From MNTECH, "If your oven would light sometimes, but usually not, or take a very long time to ignite, then replace the oven igniter. Even though it probably is glowing, it needs to draw a specific minimum electrical current (in amps) for the gas safety valve to open and release the gas. Also low voltage can affect how many amps the igniter draws, so that may be a factor, but not as often."
I live in Japan. I got a brand new range in june and it has had this problem for four month. The igniter glows but the gas never (or rarely) releases. Often it would preheat but not maintain the temp while baking. **augh** After reading MNTECH's solution I got a transformer and plugged my range into it to change the voltage (100 to 110) and I haven't had a problem since. THANK YOU MNTECH FOR POSTING THIS SOLUTION
Aug 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Oven will not light
ignitor lights up , so im assuming its a glow bar style ignitor. replace it, although its glowing its not glowing strong enough to release gas from the valve, the fact that it lights at all is a sign that the vavle isgood and control to turn it on as well!Common,Common problem
Jan 25, 2008 | Whirlpool GS460 Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
249 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
