Somewhere on the Web to go to show detailed installions of rg6 cable ends put on.
I am installing an off the air cable line, I checked the cable before installion and checked good. I shortened the cable by cuting it off and puting a new end on it. It shows shorted now, so I didnot put the cable end on right. so is there anywhere on the Web that shows detailed installion of an rg6 end being put on. Marshall
  • rexmarsh Dec 25, 2007
    I can see exactly where I went wrong puting on the rg6 cable end now, you were a great help, Bless you tom19511. Marshall
    Genius:
  • 1,601 Answers
What kind of cable to run for HD update?
I ran regular RG6 through my house and both DirecTV and Comcast work just fine. Longest run I have from source to box is about 50' if that factors into your planning.
May 20, 2014 | RCA 12' Quad Shield RG6 Coax Cable...
Please help!!!
Should be just 3 wire like old one ok match them up red white black if it has ground ok its easy once u see what your doing when u get in there ok thx for using fix ya thx nick .
Feb 04, 2008 | Hitachi C21 F800S TV
Can i use rg6 on my dx 949 radio that i am using as a base?
RG6 Cable is a 75 ohm cable and is generally used in residential settings for UHF/VHF off air antenna, cable & satellite TV signal feed lines.
The transmitter you have - like most CB, Amateur, etc. radios ant associated antennas have 50 ohm outputs and outputs. This is for a reason. Ohm's law says Maximum Power Transfer occurs when Resistance In equals Resistance Out. In order to achieve this, all the components must have matching (or close to it) resistance values. Inserting a 75 Ohm cable in a "balanced" 50 Ohm circuit can cause a mismatch or high SWR. There are ways around this - but it's too deep for here.
Your best bet would be to either try the RG6 and adjust the antenna for lowest SWR, or if unable to get it down to an acceptable value (less than 2:1 is the worst I'd accept - but 1.5:1 is significantly better), purchase a high quality 50 Ohm coaxial cable assembly instead. Good luck!
Jan 04, 2012 | Galaxy Radios DX-949 40-Channels Base CB...
What sort of wire is necessary to run a low loss RCA line extension about 70 feet?
If you can get it, Quad shield RG6 would be good. You would need to make 2 runs. It's a bit thick and you would have to find RCA ends that would fit it too. This would help from interference. Another option is RG6. This wire and the ends can be found in most home improvement stores. Something else you want to do is add a preamp at the beginning to make sure the signal is strong to begin with. When you run the wire, keep it away from any power lines. If you have to come near a power line, cross it a 90 degrees.
Apr 12, 2011 | JVC Audio Players & Recorders
Lcd Tv has colored lines
Yuu amy have a possible Gorund problem. Call the Cable Company and find out if they can install an ISOLATOR in the input of the RG6 that feed the enitire home. The ISOLATOR Should say 5-1000Ghz this will filter any noice or Hum that you see on your set..Make sure his home has a ground. If the cable company doesn't supply the ISOLATOR go online and Goole the Part..it looks like a sliver tube. It sells for $50 and up. If his using a Dish call the Dish people. Make sure the Dish is Grounded.
Mar 18, 2010 | Televison & Video
TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Apr 23, 2009 | RCA DISH Network(r) 311 Satellite System
Prong on RCA antenna cable too large for spot on Toshiba vcr/dvd
Hi, You need to look on the cable itself to see if it is an RG58 or RG59 or RG6 or RG9. On an RG6 cable the center conductor is larger than on an RG58, The RG6 cable is used for incoming cable, satellite ect. An outside antenna is not usually equipped with an RG6 unless it is of the new HD variety, which is meant to go to one of the newer tvs. You can remedy the problem a couple of ways, use the ant out on the tv if you have one or use an adapter that fits 2 coax cables together and use a RG 58 jumper from the adapter to the vcr. Good Luck!
Feb 15, 2009 | Toshiba Televison & Video
I can not install the Philips RG6 quad shield compression connectors onto the Philips RG6U cable. There does not appear to be enough of an opening in the connector to allow the dielectric to fit. I need...
First, I did not have a projection tv problem. I had a problem with RG6U cable. I solved the problem by having a cable guy sell me some compression ends. No one from FixYa ever contacted me, so I took matters into my own hands. I'm sure I would have heard back if I subscribed to your service.
Won't use you again!
Nov 25, 2008 | Philips Televison & Video
No signal
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
May 25, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
