Question about Sunpak Ultra Pro 757 Tripod
Need a quick release top for my 7575 -- we can I
Need a quick release top for my 7575 -- were can I get one
I need to contact a rep for amazon by phone. how do I do that.
1-800-201-7575
1-800-216-1072
1-800-628-3924
1-866-321-8851
1-206-266-2335
i looked this numbers up, but every time i get another number good luck
Apr 21, 2015 | Cell Phones
Missing 40 yr old Ambico tripod quick release plate 1 5/8
Take a look at www.tripodquickrelease.com or give us a call at (864)583-6835, we might be able to fix you up with a quick release. Ambico quick releases are generally hard to find, but we've found a few that will fit.
Sep 12, 2012 | Ambico V-0640 Tripod
Como entrar en los codigos de servicio pra resetear el sc541 en gestetner p 7575
sc541 means you need service techinican to come and fix your machines
Jun 20, 2011 | Ricoh Aficio 1035 Copier
I have a Koolspace 250 nuvo in my garage. It is having a hard time cooling in the summer. It is holding 68-70 degree F when set to 52 degrees. Can I make it insulated or put a fan above it to help? Can it...
You should contact Koolpace regarding this issue. They can be reached at:
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 04, 2011 | Vintage Keeper Koolspace Wine Cellar
What kind of post is there on this car for the battery, top or side post?
This vehicle has a side post battery. The NAPA part number for this battery is 7575
Nov 16, 2010 | 2007 Chrysler Sebring Sedan
I need to replace fuel pump on 1997 4-door tahoe what do i need to repair myself?
FIRST YOU NEED ROOM TO GET UNDERNEATH IF YOUR DOING OUTSIDE YOURSELF. THERE NOT MUCH THAT HOLDS THE TANK BUT TWO STRAPS, A 14METRIC OR 15 METRIC SOCKET.THERE IS ONE PLUG FOR THAT PUMP.AND TWO FUEL LINES MOUNTED ON TOP OF THE TANK.THEY HAVE QUICK RELEASE TABS. YOU WILL NEED A QUICK RELEASE TAB TO DISCONNECT. ROUGHLY 1HOUR & HALF WITH LEFT.
Sep 23, 2010 | 1997 Chevrolet Tahoe
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
Just bought a STARTER Sport Watch Model# STW14 @Walmart
TO CHANGE TIME:
1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
Sep 12, 2009 | Bulova Watch
Sunpak Ultra Pro 757 Tripod Logo
Top Sunpak Photography Experts
Tony
Jay Plesset
richie46
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
