Question about Garden
I have a homlite chainsaw and some had replaced new switches but have not written where wires go can you please help there are 2 switches with 6 wires
2 Suggested Answers
  • 2468 Answers
SOURCE: gas,oil ratio
50:1 ratio on this series
Posted on May 03, 2010
How to fix the choke on homlite 38 cc 16 inch gas chain saw
More than likely, your choke became disconnected. I have attached a link from YouTube of a video on this.
There are many useful video's on fixing chainsaws, from simple fixes such as reattaching a choke lever, to complete tear down and rebuilds.
I hope this helps you get back up and running.
Short video on fixing chain saw choke
Nov 10, 2014 | Garden
Where can I find homlite saw parts? especially the pull rope recoil
Try www.partstree.com they should be able to help you.
Sep 29, 2014 | Homelite Garden
I have a homlite chainsaw with a zama c1q h17d carburetor and need the correct fuel line routing including the oil pressurising line
One fitting on the Carb is a bit higher than the other.
The Upper one is for the Gas return when you press the Primer bulb. The Lower one is for the Gas intake...the gas line with the Filter on the end.
Is thee a small fitting for the Pressurizer on the small spacer??
Oct 01, 2013 | Homelite Garden
My Homlite chainsaw will not start. There is fuel coming out of the of the bar. It ran for a while, maybe three or four small jobs. The saw will not start. Although I am no expert I did work for Magneto...
You stated that there is fuel coming out of the bar, If this is the case fuel has gotten into the bar oil tank. Drain the bar oil tank and the fill with bar oil then drain the fuel tank and fill with fresh fuel.
Regards Outback
Apr 25, 2011 | Homelite Garden
Gas,oil ratio
May 03, 2010 | Garden
I replaceed spark plug,and still on spark. Whats next? (poulan 4218) chainsaw
Remove the flywheel side cover to expose the flywheel and ignition module. Check the flywheel magnets to ignition module gap with a thin business card for a gauge. If ok, remove the grounding wire that goes to the ignition switch and try for spark again. If still nothing, it's new module time. If removing the grounding wire got it to spark, replace the ignition switch or perhaps the grounding wire has shorted out on it's way to the ignition switch. Hope this helps!
Apr 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
IGNITION PROBLEM
You may have a difficult time finding those. I would go to the local mower shop and get an electronic ignition module and replace it with that. It will probably cost less than the points and condenser and make the saw more reliable too.
Please rate if this helps-
Mar 27, 2009 | Homelite Garden
Wire is on the botom of the motor and i dont konw what is is
Hi
Remove the fan housing.There you can see the coil.Follow those wires(2) towards the on/off switch.Replace that wire with a new one and start the engine.
best regards savumihai71
Feb 12, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
