Question about Garden
Have ryobi 35 head, does not get gas, everything ok. someone said that the gas tank has a filter clogged or line broken. primer seems to be pulling air.
  • 279 Answers
If you are pulling air and you don't get enough fuel, the filter in the tank may either one that is weighted and is just placed on the end of the fuel line. Or it could be one that is attached to the tank with a nipple sticking through and held in place with a ring around the fuel line and pressed up tight to the tank, over the nipple. There is also the possibility that your fuel line is broken somewhere. If you cannot see the break, it would be inside the tank. Good luck,,,Lee
Posted on Oct 08, 2009
The primer bulb is broken on my 700r 2-Cycle Gas Trimmer and I would like to replace it
not difficult at all to do , first obtain Ryobi primer /fuel line kit from your local distributor , then remove air cleaner cover (pops off with fingers) then drain all gas from fuel tank back into storage tank , locate the two Phillips head screws next to primer bulb and remove them , careful not to drop them !! remove old bulb from ring and replace with new bulb from pkg. then using a clean cloth , carefully wipe out sealing grove where bulb seats down (I guarantee its dirty) when all clean , place bulb down in grove and make sure it seats well then secure with ring and replace screws (don't over tighten) you might as well replace the fuel lines as they come in kit , instructions are on pkg , I do suggest doing one at a time to not forget how they go , and do use the new fuel filter that's inside pkg too
May 13, 2016 | Ryobi Garden
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
Ryobi 30cc was running ok and then cut out. Not been able to re-start since
First check vent in fuel cap to make sure it is not clogged, then check to see if fuel filter inside the tank is obstructed or if fuel intake line has softened and is possibly collapsing...pump primer bulb and see if it is sucking gas into the carb...next choke engine and try to start...if it doesn't start pull the spark plug to see if cylinder is getting fuel...if so re attach plug to the plug wire and ground plug to cylinder head....pull start handle and check for spark at electrode of plug....or put a little gas in plug hole and re-install plug ....pull starter handle a couple of times and if engine starts and runs for a second, you have spark....Your problem sounds suspiciously like your carb has ingested some trash and is clogged which will necessitate a good cleaning and re-tuning...possibly a rebuild...Hope this helps... ;-D
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I need to know how the fuel lines are hooked up in my ryobi gas trimmer. All of the fuel lines rotted out. I took them out and I need to know the correct connection sequences (what goes where).
line runs from little filter in tank to carb.
line from carb. to primer bulb
line from primre bulb back to gas tank.
lines are 2 sizes
need to cut at angle end of lines in tank so you can get them thru holes
and grab with needle nose plyers and pull them thru.
make sure you put the little filter on end before you pull line thru and leave
enough so filter can move around the whole tank.
second line in tank is smaller and need to cut and pull it thru hole in tank to primer bulb
Jun 23, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a ryobi lawn and garden trimmer. SS26 (i t...
The fuel filter in the tank could be plugged, a fuel line gone bad, or the primer bulb has cracked, gotten hard, or otherwise rendered useless. It's possible that the lower chamber diaphragm in the carburetor is bad--hardened or cracked. The primer is supposed to pull fuel from the filter in the tank, into and through the carburetor, then out to the primer bulb, then back into the tank through another line. Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetors--very helpful. Hope this helps!
May 20, 2010 | Garden
Replacing broken gaslines... were do they go?
the primer bulb draws gas through the carb 'C' and back to the tank'T' leaving a small amount of fresh gas in the carb.to replace the lines from filter to carb & bulb to tank,you may have to remove handle & split the housing halves to find where lines enter tank.look in tank W/ a flashlight.to replace lines cut new line on an angle,feed a piece of # 14 copper wire through hole from inside tank.slide new line over wire,the wire will help align fuel line with hole.use needle-nose pliers to push line into tank,& to pull it through once you can see it.cut off end of hose you beat up with pliers.push filter on hose to carb.drop it back in tank."T' line is the return.dosn't matter which line is through top or bottom hole.
Sep 21, 2009 | Ryobi Factory Reconditioned 18" 40cc...
RYOBI 725R FUEL LINE DIAGRAM
I just rebuilt my 725r. I don't have a diagram but I can explain it. There are two lines coming out of the fuel tank. The line closest to the rear is the fuel feed and has the in-tank filter (these are available for replacement). This line goes through the lower case hole of the air filter housing and attaches to the bottom of the carburetor. The line toward the front of the tank attaches to the longer/lower fitting the primer bulb and is the return. The line coming off the shorter/upper fitting of the primer bulb goes through the upper hole of the air filter housing and attaches to the top of the carburetor.
FYI also, the forward carburetor screw is the low idle adjustment & the rear, the high-speed mixture. The original oil mixture spec called for 32:1
Jun 13, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
