Question about GE Profile PGB918 Kitchen Range
GE profile convection/bake gas oven shows accurate temperature with a digital read-out sensor, but cakes come out overbaked, with visible air holes and hard "skin" on the outside. At times the outside of the cake has been so hard that you can actually "knock" on it. GE will do nothing more after two service calls where the tech said everything is OK and insist I must be doing something wrong when I bake.
  • GE Master
  • 10,045 Answers
My oven is at least 10 minutes fast when set at temperature, so I just check what is baking several times so that doesn't happen.
Posted on Jul 28, 2017
SparkGap
  • 363 Answers
SOURCE: GE electric oven
If this is a fan oven, make sure the fan has not become clogged or has stopped rotating.
Posted on Oct 07, 2007
  • 311 Answers
SOURCE: items are not baked all the way through
Put a thermometer in the oven to see how the temp is vs what you set it at. If temp is off by more than 25 degrees replace the oven sensor. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
SOURCE: GE Profile Spectra JGBP85WEB5WW Taking Too Long to Reach Temp
GE use and care manuals
Posted on Dec 06, 2008
  • 126 Answers
SOURCE: No Bake; everything else works
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Posted on Jan 28, 2009
Maytag317
  • 1136 Answers
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
My defy double door gourmet thermo oven overbakes cakes on the outside what should i do to ensure even baking
Reduce the temperature slightly or get an oven thermometer and follow the recipes.
Aug 01, 2017 | Ovens
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
F3 and F2 Errror messages on my GE convection oven
F2 & F3 are fault codes relating to the oven temperature sensor
F2 during bake means a temperature of over 630 deg has been reached
F3 means shorted oven temperature sensor
What it means is you will most likely need to have the oven temperature sensor (thermostat) replaced .
Dec 19, 2010 | GE Profile JTP56 Electric Double Oven
Oven with convection - when baking cookies, cakes, etc they aren't getting done. Bottom and middle is soggy. Both coils look to be heating, convection fan is working.
Set the temperature one position higher. Convection ovens have a more even heat spread so if you used to bake at the top of your old oven it will now be slightly lower temperature
Dec 06, 2009 | GE Profile JB900BK / JB900KK / JB900TK...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Baking cake and F2 signal
F-2 on your range indicates a bad temperature sensor. Please replace your temperature sensor in the oven.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Baking with digital oven
First let me address the temp ... Buy a meat thermometer and test it against the temp set in the oven.  Though that isn't the most accurate, it should prove whether or not it is way way off.
Second.. convection baking takes considerably less time....
Third... elevation plays a key factor on baking but not so much on cooking meat.  Baking above 2500ft elevation takes 20% longer and above.
Mar 08, 2008 | GE Profile JTP18 Electric Single Oven
Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
Touch the Bake and Broil Hi/Lo pads
display shows SF.
Touch the Bake pad. A two digit number
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
to change the oven temperature 15°F,
touch 1 and 5.
touch the Start pad to go back to the
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile PGB918 Kitchen Range Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
