Question about Panasonic DMR-ES30VS DVD Recorder/VCR
I have a Panasonic DVD REcorder Model No. DMR-ES30V connected to a Westinghouse 32" LCD tv.
I have a Panasonic DVD -VHS Recorder Model No. DMR-EX30V connected to a Westinghouse 32" LCD tv. Prior to moving the recorder to this t.v., it was connected to a Sharp t.v. and worked fine, recording, etc.
The recorder has worked as a DVD player on the Westinghouse and I have dubbed some VHS tapes to DVD with it, since it has been connected. This past week, I tried to record a tv program and got nothing but static and noise, over and over.
I have referred to the Panasonic recorder's manual and started an automatic set up twice and each time it has failed to find any channels (on cable). I then tried to do the set up manually, according to the manual, and still, it does not recognize any channels. I know that there is no code number for the Westinghouse tv in the manual and that it states that the remote may be incompatible with the tv if it it's code is not listed in the manual. I presumed that just meant that I wouldn't be able to control the tv with the remote for the recorder, sure was hoping that it didn't mean that the whole system would be incompatible. Is that the case? If not, what can I do to get it to work?
SOURCE: Panasonic DMR-E85 DVD recorder TV Guide problem
Try unplugging the DMR-E85 power cord. It is important that you unplug it from the back of the recorder, not the wall. Leave it unplugged for 10 or 15 minutes. For good measure disconnect the cable 'in' connection as well. Once both lines are plugged back in it will go through its self-check diagnostics. Leave it alone for awhile (give it time to consider the error of it's ways). If you are lucky, when you turn it back on it will ask you to verify the channel lineup. If this does work, and all the channel info is correct, press 'enter' (lineup 1 highlighted). Good luck! This is an awesome machine, WHEN IT WORKS!
Posted on Jan 24, 2009
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
Benimur
  • 6966 Answers
SOURCE: My Dad recorded all his VHS tapes and made DVD's
Hi and welcome to FixYa,
My compliments to the foresight of your father. Your described concern is not caused by a "lock". It is indicative that the recording session was not 100% completed. Rather than 'crack', what is required is the final step in the recording. All the DVDs must be "finalized" in the same machine that recorded the movies, the Panasonic DVD Recorder DMR-ES30V. The finalize option would be in the MENU/Settings and must be enabled. Finalization per disc would take some time.
Good luck and thank you for using FixYa.
Posted on Feb 18, 2009
welcomejee
  • 10594 Answers
SOURCE: VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Posted on Apr 16, 2009
nandosnut
  • 112 Answers
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Posted on Apr 18, 2009
I need manual for Panasonic DVD/VHS recorder DMR_ES30V
Hello.
You can download the manual you need using this link:
Panasonic DMR ES30V
It is a PDF file so if you can't open it, download and install Adobe Reader:
Adobe Reader
Please rate my answer.
Aug 03, 2011 | Televison & Video
I have a Panasonic DMR ES30V DVD/VHS recorder. Sometimes the DVD recorder will stop (generally in the first 30 seconds) and a Check light will show. I then have to shut down the unit and restart. ...
I had the same problem with my DMR-E30VS. I tried a disk cleaner, that did not work. I took the cover off cleaned the lens witk a Q-tip and Isopropyl (rubbing) alcohol. It works fine now!
Jun 28, 2011 | Panasonic DMR-ES30VS DVD Recorder/VCR
My panasonic vhs/dvd recorder DMR-ES30V. DVD will not open and shows error code U99
Error indication u99
After development of the DVD drive and the frame lying under this the cause is nearby a horizontally placed circuit board one Elko 630 uF lid which ones probably lifted presumably is.
Jan 11, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
My Dad recorded all his VHS tapes and made DVD's on the Panasonic DVD Recorder DMR-ES30V and now they wont play on any DVD player except for the DMR-ES30V. I believe he recoreded them with a lock so they...
Feb 18, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
PANASONIC DMR-ES30V KEEPS SWITCHING OFF
I had this code (f09) on my Panasonic DVD VHS recorder. After seeing that it meant overload I took the cover off to look for burnt out components. I found that an electrolytic capacitor had bulged (look up capacitor plague on wikipedia). I replaced the capacitor with one of a similar value from an old power supply and it worked fine.
Feb 16, 2008 | Panasonic DMR-ES30VS DVD Recorder/VCR
Panasonic DMR-ES30VS DVD Recorder/VCR Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
