Question about Rowenta Perfect Iron DX9300 Iron with Auto Shut-off
Exploded view looking for exploded view for the rowenta DX9300
Switch not working hoe can i replace
Good evening Melinda!
You can look here for replacement parts
Rowenta DG5030U0 B80 Pro Master Iron Parts , (amongst others), and a closer look at the 'Housing, front complete'
Housing Front Complete shows it includes an on/off switch.
It's not a 100% match, but this video showing dis-assembly / troubleshooting another Rowenta iron will probably get you to where you need to to replace the part (and might allow you to see if it's just a disconnected/broken wire and save the $17 for the part!)
Hope this helps, and good luck!
D
Nov 19, 2015 | Rowenta DG5030 Iron
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
The top plastic piece that runs the length of the top of my Rowenta DE 831 broke. Can I get a replacement part for this? Can an exploded view of the parts be obtained, or a manual? Thanks.
Only if you check up with Rowenta this part will be available but if you can search around in service shops you may be able to salvage one from a coil damaged iron that was discarded.
If not fabricate the top with a fibreglass or plastic repair shop and it can be doe to suit the top after a paint job.(If broken use good glue and then paint on top)
Aug 31, 2010 | Rowenta DE851 Iron
Sometimes the auto shut off doesn't work and it
In poking around, I find way too many hits on the name which once was a good one while I lived in Germany. They have exploding irons, coffee makers that turn themselves on and can catch fire, even a 'lighter' (wasn't described) being recalled. If you have any warranty on that unit or if Target agrees to refund your purchase price, I wouldn't recommend trying Rowenta again-
Nov 10, 2009 | Rowenta DZ1700 Iron
My Rowenta iron is leaking down by the cord. can
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 16, 2009 | Rowenta Professional DE880 Iron
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
Dec 26, 2008 | Rowenta Professional DE871 Iron
Rowenta DG980 Owners Manual needed
Go to the Rowenta USA website. They will have a users manual in PDF format (you will need Adobe Acrobat Reader to be able to view, download or print the manual. It is free...yay! :o)
Sorry I cannot attached the hyperlink because my Internet Explorer keeps locking up when running on my new VISTA equipped machine.
Aug 26, 2008 | Rowenta DG-980 Iron
Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
Jul 05, 2008 | Rowenta Perfect Iron
Rowenta Perfect Iron DX9300 Iron with Auto Shut-off Logo
83 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
