Question about Minolta Office Equipment & Supplies
Minolta DI183 When power is turned on. Copier lights up and than trips power switch off. Error display = COS + 000
  • Minolta Master
  • 1,294 Answers
Lower drive motor blocated.Check,measurement and change the motor or the master board.Check the fusing unit gears and the rollers.
Posted on Oct 08, 2009
Minolta di183 driver x64
Sir the Minolta Di183 is a Legacy copier from Minolta at best you mite find Windows 95 or XP at best. Not going fine Windows 7 Vista. But try the konicaminolta web site. Drivers are free.
Jan 08, 2014 | Minolta DiALTA Di183 Copier
C06 50 error code minolta dialta copier
The scanner which is the bright lite under the big glass has a home sensor to let the copier know that scanner is back home and ready to scan again. will the code is saying the senor is bad, could be dirty get some can air. Remove big glass will be though to get at small and black under the scanner bay side.
Dec 02, 2013 | Minolta DiALTA Di183 Copier
Minolta dialta di183 copier error code c06 50
C 0650 - Faulty scanner home position sensor.
Remove the glass and clean the home sensor.If the scanner moves smoothly remove foreign matter and other obstacles,clean the scanner rails,clean or change the scanner bushing.Place WD 40 oil on scanner bushings.
My dialta minolta di183 is showing C06 50 code and i dont know how to go about it
Clean the home scanner sensor scanner is what moves as it scans the document. then go back to home position there is sensor that tell the copier it is back home clean dirt or might need to be replaced.
How to stop maintenance indicator light in Minolta di183
Replace the drum and developer. Ensure the tech clears the counters once done. If you clear the counters with out replacing the parts the copier works on the counters the copier will set the voltages for certain parts assuming there where replaced and since they where not, image problems could happen and certain codes appear.
Jun 12, 2013 | Minolta DiALTA Di183 Copier
How to reset error code c0500 on minolta di183 copier machine
Power off the machine wait ten seconds then power on holding down the stop key button. If the code comes back get a new fuser unit, continue to reset with out new fuser could cause a fire that would ruin a perfectly good day!
Apr 10, 2013 | Minolta DiALTA Di183 Copier
How to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
Apr 04, 2012 | Minolta DiALTA Di183 Copier
I get an error code on our Minolta DiAlta Di183 FF-CO3
Press the panel reset screen until intial screen appears
Nov 03, 2010 | Minolta DiALTA Di183 Copier
Pcl xl error
Di183 standard m/c with GDI printer,to Print thru PCL driver u need to have Image controller installed in the m/c. So delete the printer driver & install the GDI printer driver.
Mar 13, 2009 | Konica Minolta DiALTA Di183F Copier
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
