Question about Roper RAS6233KQ Top Load Washer
WASHING MACHINE FILLS WITH WATER GOES NO FURTHER
MY ROPER RAS7133PQ0 WASHING MACHINE FILLED WITH WATER AND WENT NO FURTHER. REPLACED LID SWITCH AND STILL NOT ABLE TO AGITATE OR DRAIN.
Not too familiar, but just replaced my lid switch (but that worked) and thru my research I found could also be the belt, so try researching that, sorry could not be more help
Posted on Oct 12, 2009
Washer fills with water and stops
You possibly could have a bad lid switch. The machine may think you still have the lid up and that is why it stops and will not do anything else.
Feb 10, 2015 | Roper RAS8445KQ Top Load Washer
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
I have a roper whirlpool washer that only runs the water and then it stops, how can I repair this?
This is a common problem, your lid switch is to blame, the filling of the machine is only dependent on the timer knob being pulled out at cycle start. Once the machine fills and the level actuates the level switch to de-energize the fill valve, nothing else is going to happen until the timer motor powers up AND this is done by closing the lid to operate the lid switch, however if this switch is bad, the rest of the electrical circuit gets no power, and that is why your machine doesn't advance any further in it's cycle. Lid switch is mounted under top of machine and requires the cabinet to be properly removed for access.
Hope this helps
kcomp1863
Nov 29, 2010 | Roper RAX4233PQ Top Load Washer
Washer wont work
This sounds like the lid switch went bad. If you put it back on the wash cycle and it agitates, but will not pump out and spin, more than likely it needs a new lid switch. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try and get you fixed up.
Jan 06, 2010 | Roper RAS8445KQ Top Load Washer
Roper washing machine (ax6245vw0) fills, will drain, will spin, but will not agitate. replaced lid switch today (it was broken), put all back together, now won't agitate
Good morning! please review/check the connections made of the new lid switch, taking note of its polarity. best regards
May 02, 2009 | Washing Machines
Washer wont start
If the machine fills with water normally but then just sits there, you might have a bad lid switch - that's the safety interlock that won't let the machine start unless the lid is closed. Check the switch and also make sure the lid engages it when you put the lid down. Of course there could also be a problem with the motor, but first check that switch.
Mar 08, 2009 | Roper Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
I have a Roper washing machine that will fill with water, agitate, and stops. I replaced the lid switch assembly and tried it again. Same thing, but one step farther. It went past the agitate and...
The black dust is from the motor coupler. It is normal to have some under the unit. If it stops completly and you chaged the switch check the lid adjustment if the lid is loose it might not make the switch all the time.
Apr 24, 2008 | Washing Machines
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
150 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
