I have a HP ZD8000 Laptop.I get square patterns across my screen and sometimes just vertical lines. the problem sometimes goes away but also gets worse when I put pressure on the LED panel.
If you are getting the same screen in BIOS then the LCD screen has gone bad and needs to be replaced but if not then do a BIOS update and then reinstall the video driver and restart the Laptop.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion zd8000 PC Notebook
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into...
(More)
Had two red lines then the last time i turned it on it lasted about 5 minutes then went into hibernation and now it will not turn on at all
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list...
(More)
Why is my outlook express dropping the contacts in my contacts list The contacts in my contacts list just disappear and are not to be found.
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple...
(More)
i have the same issue...a black scriggly line appeared at the top and gradually over the last couple of weeks has made its way down the screen. This is a new laptop and I haven't taken it anywhere and handle it with great care. Any ideas as to what I can do other that ship it back to Toshiba?
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success....
(More)
hp zd 7020 us video is distorted is there a fix. i have tried different drivers and no success. color is off and picture distorted
I have a toshiba with now 2 lines running down the middle of the screen, present upon startup,...
(More)
I have a toshiba with now 2 lines running down the middle of the screen, present upon startup, before windows, and, the second one just appeared today...is my screen going bad? how would I replace?
