Question about Car Audio & Video
Auto i have a 1991 dodge dynasty.the security systemstopped working, it controls the fuelpump and door locks ,also theftlight on dash stopped working. car starts but shuts back down. how can i bypass this to get car started. can you help me?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Remove the immobiliser. Your engine immobiliser is what is shutting your car down. You may need an Auto Electrcian to help you with this one, as one immobiliser is out, you will still want you central locking to work from control.
Posted on Feb 13, 2008
1991 dodge dynasty odometer not working
sorry to say you need to change the cluster
Oct 12, 2016 | 1991 Dodge Dynasty
Where is the turn signal flasher located on a 1991 dodge dynasty?
under the dash around the steering column or mounted near or on the fuse panel. it looks the same as the hazard flasher.
Oct 11, 2014 | 1991 Dodge Dynasty
No spark
Check for a faulty ignition coil, you can go to your nearest auto parts they should take care of you.
This is how your 1991 Dodge Dynasty ignition coil looks like.
Hope this help..
Oct 11, 2010 | 1991 Dodge Dynasty
I have a 1889 dodge dynasty it starts and runs a few secands and turns off it restarts and the same thang happins it started this after the battery went bad could this be a securty prob
The alarm system, which is activated by hitting the auto-lock button, causes the battery to drain if set off. A pretty good deterrent for theft, but definitely not a owner-friendly feature.
You'll know that the alarm was triggered if, upon (your sad attempts at) starting the 1989 Dodge Dynasty, the "Alarm" signal to the left of the steering column flashes. It normally would flash a certain number of times, to denote "Alarm Set Off! I have drained the battery power in the name of Security!" But usually you battery will die first.
The only way TO FIX THIS PROBLEM: exit the vehicle. Place the key in the driver's side door. Turn the key once to the left (counterclockwise) to lock it. Then turn it to the right to unlock it and open the door. Enter the vehicle. Start the car.
You may have to try this a few times in order to be successful. If your battery has been toasted by these attempts (sometimes the horn will honk and headlamps light up and flash for added battery-drain quickness!) you may need a jump.
To PREVENT THIS STUPID STARTER/ALARM PROBLEM: Simply use your hand to lock the door. Do not push the electronic auto-lock button.
Jun 07, 2010 | 1989 Dodge Dynasty
1991 Dodge Dynasty interior dome lights won't shut off
First, check the dimmer switch (should be the same as the headlight switch) and make sure it is not turned all the way to the right as that will turn on the overhead light.
If you are sure the door switch is fine, then I would replace the dimmer switch.
May 14, 2009 | 1991 Dodge Dynasty
Needing wiring diagram for 1991 dodge dynasty le
here is what I found:
Mar 26, 2009 | 1991 Dodge Dynasty
go to your local auto parts store they will print one out for you advance auto or auto zone is your sure bet
Jan 05, 2009 | 1991 Dodge Dynasty
1990 dodge dynasty 3.3 engine starts fine but a second later dies changed gas filter and fuel pump and regulator still don't stay started.
Same thing happened to my '89 Dynasty. Turns out the security system was engaged and this stops the motor from running; therefore. a thief cannot drive away with the car! The system is set by using the power locks or an autolock fob, but not by locking manually. Disconnecting the battery will also engage the security system. To disengage, close the driver or passenger (front) door and turn the key in the lock.
Aug 19, 2008 | 1989 Dodge Dynasty
Car Audio & Video Logo
430 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
