Question about Hotpoint Dishwashers
The water won't drain out of the bottom of the dishwasher.
The water won't drain out of the bottom of the unit, and the water level is building up.
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/control sector(board)
Replace if defective (note: uncommon problem).
Posted on Oct 07, 2009
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Tip
LG Washing Machine has an OE error code
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service<br /><br /><b>Step 1: Check the drain pump filter.<br /><br /></b>Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine<br /><br /><b>Step 2: Check the washers drain hose.<br /><br /></b>If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine<br /><br /><b>Step 3: Confirm that the washer is leveled properly<br /><br /></b>If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice-versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confirm that the washer is leveled from side to side and front to back.<br /><br /><b>NOTE: </b>Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
on Jun 02, 2011 | Washing Machines
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
My frigidaire professional dishwasher won't drain
In the bottom of the unit, do you notice clean or dirty water? Do you have the unit connected in the same drain line as a garbage disposal?
Aug 31, 2012 | Frigidaire Dishwashers
Dishwasher won't drain
If you hear the motor running when it is to be draining you may have a busted pump impeller. Also locate and check the round looking cap it will move up and down by your hand pull it up if it is stuck at the bottom this is your float level it goes up and down with the water level the pump will not switch over if it is stuck on the bottom if it is stuck it is telling the dishwasher it is empty of water. and last but not least your wash timer may be out.
Apr 07, 2012 | AEG 23 in. Favorit 44070Vi Built-in...
Water won't drain
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter located inside the front bottom access panel for any clogs/obstructions, if you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 18, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Will not empty water
Hi.
If the machine does not drain you usually have drain blockage. Clean the drain well at the bottom of the tub. remove and clean filter and assembly parts. Make sure that the drain hose at the back of the dishwasher is not kinked.
Several Miele dishwasher uses a pressure switch to determine the water level. A defective pressure switch may prevent the machine from starting.
If this model uses a pressure switch, the switch will be located in the drain line. When a pressure switch is defective the machine should return an error code. Here a picture of the pressure switch:
If that does not fix the problem the pump located under the bottom panel must be tested.
Regards.
Ginko
Dec 15, 2011 | Miele 24 in. G2180Vi Built-in Dishwasher
Ice build up in the bottom of the freezer compartment to the point that it will flow under the gasket like a glacier and melt. There is not an icemaker hooked up. No free water is piped to the unit and...
You have a common problem of a clogged drain, in the back bottom of the freezer, behind the shelf and drawers, you will find a drain pan that has frozen completely over with a ice sheet. This has caused defrost water to run forward and collect under your racks in the freezer. I would advice you to turn off unit, and remove all the ice collected in the freezer, clear the pan with warm water, then restart your unit back up.
Once the pan and drain tube is clear, your unit should be fine.
I hope this helps
Aug 02, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
After starting the dishwasher with time 56 min, the time goes down to 55 min and after that time remains 55 min. After few min there it showed 0E in the display bar and it stopped working. Is that...
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
May 02, 2011 | LG Dishwashers
OE problem
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Feb 19, 2011 | LG WM2301HW Front Load Washer
Dishwashers Logo
242 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
